Starter bind - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 07-19-2019, 01:43 PM Thread Starter
whitefire2.0's Avatar
Starter bind
I just dropped a 98 12v into an 03 f250 in front of a nv5600 and fired it off with no issues with a brand new starter. The engine and trans had to be moved slightly for alignment purposes and now no matter how I shim or adjust the starter it is so bound up it won't even turn the motor over and it locks down the entire drivetrain. Any ideas would be appreciated.
Sent from my SM-G955U using Tapatalk
whitefire2.0 is offline
post #2 of 9 (permalink) Old 07-19-2019, 01:54 PM
9297oldram's Avatar
Was the engine, starter and transmission a unit when you got it? Or is everything pieced from different places?
9297oldram is offline
post #3 of 9 (permalink) Old 07-19-2019, 02:07 PM
GAmes's Avatar
iTrader Score: 7 reviews
The adapter plate for the NV5600 is different than that for the NV4500/automatic transmissions. The early ones employed a spacer, the later version was made with a thicker mounting plate. I thought a had a picture of them side by side but can't find it. Have you measured the flywheel spacing? This is what it should be. On another track, if you didn't use an adequate starter, i.e. Mopar or Denso, made for a 12 valve the one you have may have failed.
Name:	flywheel to face 1 15-16 inch.JPG
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #4 of 9 (permalink) Old 07-19-2019, 03:05 PM Thread Starter
They were a unit. And it worked before moving the transmission and engine around.
post #5 of 9 (permalink) Old 07-19-2019, 03:26 PM
9297oldram's Avatar
Was the starter removed at anytime? Maybe it got bumped hard at one point of the install and it's not straight.
post #6 of 9 (permalink) Old 07-19-2019, 04:51 PM Thread Starter
I've removed it and replaced it about 20 times and no matter how it's installed it binds the entire drivetrain lol
post #7 of 9 (permalink) Old 07-19-2019, 05:38 PM
9297oldram's Avatar
Have you tried removing the starter and then turning the engine over with a barring tool to see if it binds?
post #8 of 9 (permalink) Old 07-20-2019, 01:38 AM
Fire god's Avatar
Or... Bumping the starter after uninstalling?
95 3500 auto, bhaf, 4k, kdp, gauges, air bags, fuel htr delete, 33"s, dually spacers, 4.10 lim slip, 2" level, silicone hoses, tps delete, tcc switch
Fire god is offline
post #9 of 9 (permalink) Old 07-22-2019, 07:51 AM
9297oldram's Avatar
Did you find out the problem yet?
