How screwed am I, overheated and now seems to have low power - Dodge Cummins Diesel Forum
 7Likes
post #1 of 31 (permalink) Old 07-18-2019, 04:20 PM Thread Starter
Bought my first 12v last night! Did a test drive and everything seemed fine until I parked it. Small amounts of smoke coming from the hood, popped it up and it was coming from the top of the engine, with a slight smell of oil. Owner claimed it just hadnt run in a while and a friend of mine confirmed that his does that from time to time. Paid the piper and left.
Got about 2 miles down the road and realized that it was overheating, pulled over and found that the hose on the bottom of the radiator was disconnected. Filled it with water (that was all I could do on the side of the road) and drove it home. Overheating has gone away but it doesn't seem to have the power it should seemed to struggle to make it up my relatively steep driveway in second gear. The engine seems to be "loping" almost like not all cylinders are firing.
I am not great at diagnosing this stuff yet, any ideas on what I should be looking at first? Or have I just dumped a bunch of money down the drain? Previous owner is MIA, wont return calls or texts.
Anrkist is offline
post #2 of 31 (permalink) Old 07-18-2019, 04:32 PM
The Uppity 12v Guy
dauntless89's Avatar
Did it leak all the coolant out or was it empty when you left?
Probably lost the head gasket and has low compression in a couple cylinders.
Worst case, it overheated to the point of warping the cylinder walls and it needs a rebuild to be "right."
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #3 of 31 (permalink) Old 07-18-2019, 04:33 PM
Moderator
9297oldram's Avatar
If it has low power it could also have a plugged fuel filter or the FSS ( fuel shutoff solenoid ) may not be pulling all the way up. Best thing to do is to pull up all the way on the FSS arm and tie it up and take it for a drive.
9297oldram is offline
post #4 of 31 (permalink) Old 07-18-2019, 05:34 PM Thread Starter
Yeah pretty much all the coolant was gone
Anrkist is offline
post #5 of 31 (permalink) Old 07-18-2019, 05:39 PM Thread Starter
Sounds worth a shot, I will see if I can figure out how to do that.
Anrkist is offline
post #6 of 31 (permalink) Old 07-18-2019, 05:39 PM
The Uppity 12v Guy
That doesn't answer the question.
Was the engine dry when you left the seller, or was it full and the hose popped off while going down the road?
post #7 of 31 (permalink) Old 07-18-2019, 05:47 PM Thread Starter
I believe it was dry when I left the seller hence the small amount of smoke and oil smell that should have tipped me off. The first time I looked at the temp gauge was after I paid and left. It was pegged out. Honestly I didn't even think to check the fluid. I know it's a novice mistake.
Anrkist is offline
post #8 of 31 (permalink) Old 07-18-2019, 05:59 PM
ddurr92's Avatar
Well assuming all issues are good, no headgasket or anything bad like that, since this is ur first 12v, just know these trucks already are underpowered.. they are dogs until u tune them up.
Sent from my SM-G955U using Tapatalk
ddurr92 is offline
post #9 of 31 (permalink) Old 07-18-2019, 06:02 PM
The Uppity 12v Guy
Mistakes happen. Just trying to figure out what level of predicament you're in. If the hose popped off on the drive home you almost certainly would have smelled antifreeze and it would have left a huge wet mess under the truck. If it was bone dry down there and no antifreeze smell, it was likely dry when you left.
The oil smoke isn't necessarily a major red flag, any truck with leaky valve cover gaskets will get that on startup as the oil runs onto the exhaust runners. That said, I've never seen that result in an amount of smoke you could see with the hood closed.
It will take a long time for a dry engine to show on the gauge as overheating, as heat will only be conducted through the block to the sending unit instead of through the coolant under active circulation.
I would fill it up with coolant and drive it around a bit, see if coolant & oil are mixing, either are leaking externally, if it's consuming coolant, or if it's pressurizing the cooling system (look for bubbles in the overflow tank). Those are the 4 symptoms of a bad head gasket.
post #10 of 31 (permalink) Old 07-18-2019, 06:36 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
if the seller sold you a truck that was low on coolant, he probably didnt do much maintenance on it to begin with so you should go ahead and flush the system. Get your self 3 gallons or the green or yellow (mix with anything) antifreeze coolant and 3 gallons of distilled water. I would pull the thermostat and stick your water hose in the block, heater core and radiator. Get new upper and lower hoses as well since the old ones are falling off.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #11 of 31 (permalink) Old 07-18-2019, 09:47 PM
Loud Pedal's Avatar
Ya, that's not true.....There is certainly more power/HP to gain, some free...but even stock trucks (at least manual's) are not dogs even with factory settings....
98-4x4 5spd
Loud Pedal is online now
post #12 of 31 (permalink) Old 07-18-2019, 11:13 PM
ddurr92's Avatar
Mine was haha. Idk why. Lol
ddurr92 is offline
