No 2nd gear on culumn shifter 47re - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 07-16-2019, 08:11 PM Thread Starter
LefflerWorks's Avatar
-Hello, I have been searching Hi and low and can't find info on this particular Issue. Started 2 weeks ago: No 2nd gear with column shifter.
shifting manually 1 to 2 , stays in 1, until D, then will shift fine, 1234. Downshifting from D to 2 will shift into first, and stay in first. Used to work until 2 weeks ago. Other than that, it shifts perfectly.( The TPS also went out the same day the issue started, ((random lock up and unlock)) but that is no longer an issue.) Any help would be greatly appreciated.
~Landon
LefflerWorks is offline
post #2 of 4 (permalink) Old 07-17-2019, 03:12 PM
pa coal roller's Avatar
Not having 2nd gear manual would be a valve body issue. Or in the linkage.
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
post #3 of 4 (permalink) Old 07-18-2019, 01:04 PM Thread Starter
Thanks for the Reply, any Idea what I should be looking for wrong in the valve body? or a good source for info?
post #4 of 4 (permalink) Old 07-19-2019, 04:00 PM
Do you do a lot of manual shifting?
Factory service manual (see the sticky at the top of the forum for a link to download a free copy) or ATSG manual are your best sources of info.
'96 2500 club-cab, long bed, 2WD - Dipricol trans/boost/pyro gauges, ISSPRO fuel pressure gauge, +2qt Chrysler trans pan, Sport headlight retrofit & suvlights conversion harness, fuel heater deleted, KDP tabbed, Raybestos WC37290 (1-1/16") wheel cylinders
texasprd is offline
