Stiff pedal on startup - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By nSaEvAyL
post #1 of 4 (permalink) Old 06-13-2019, 10:54 PM Thread Starter
ehenle4188's Avatar
My 97 has a #10 plate slid 3/4 of the way up with 512 injectors. Truck was running a little but smokier than I like so I turned the star wheel back a little bit (it was full fwd) and also backed out the smoke screw a little (it was turned all the way in). Truck runs great now except when I start it the throttle is super stiff. I've always had to give it a tiny bit of throttle when starting it. After it's running I dont notice the pedal being stiff. Any ideas?
97 cummins 4x4 nv4500
california truck
FP, boost, pyro
ehenle4188 is offline
post #2 of 4 (permalink) Old 06-14-2019, 12:02 AM
Never been in a 12v that doesn't do this. Hard to push the peddle, then it just gives. Or start it and it's fine.
I think it has to do with the AFC arm sticking to the guide it slides on. Once you unstick it, oil coats it and eliminates this problem until you leave it sit for a while. Then it all starts over again.
That is my working theory. No proof of that.
dd453ford likes this.
98 12v SC 4X4 114K Miles, A5K, SDX 5X18, 4K GSK, KDP, Custom VB, Deep Pan, Peak Diesel IC/B, Devils Own W/M, Head Studs, 60lb VS, 2095 Rack Plug, Barrels moved, Guages (EGT, Boost, Trans Temp), Timed 22* http://s1057.photobucket.com/albums/t398/lwilde13/
nSaEvAyL is offline
post #3 of 4 (permalink) Old 06-14-2019, 03:00 AM
Mine is the same way, stiff pedal until you hit the starter. The moment it starts cranking the pedal gives and the engine fires up.
1995 RAM 2500 Club Cab Laramie SLT 2 W/D 5.9 P-Pump w/ NV4500 3.54 Dana 80. Nearly stock. Timed @ 15.5* Currently 318,000 miles and counting.
dd453ford is offline
post #4 of 4 (permalink) Old 06-14-2019, 07:08 AM Thread Starter
ehenle4188's Avatar
Glad to know it's not just me. I can live with it. Was just wondering because it was smooth as butter until I messed with the star wheel and smoke screw. Runs much cleaner now so all is good. Thanks!
california truck
FP, boost, pyro
