1996 lost power - Dodge Cummins Diesel Forum
 5Likes
post #1 of 39 (permalink) Old 06-11-2019, 05:49 PM Thread Starter
pa coal roller's Avatar
1996 lost power
I have a 1996 3500 dump truck that all of a sudden lost engine power truck is bone stock with a 5speed 120000 miles on it. Truck is not mine. Fuel filter was change out. The truck lost engine power cant even pull a hill only in 2nd gear. The Watergate rust open took that off wired it close it help a little bit. The truck was to a shop they said it need an injector pump but I am not sold on that. I am thinking theres something wrong with AFC housing or fuel issue. Would the fuel shut off do this?
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is offline
post #2 of 39 (permalink) Old 06-11-2019, 06:23 PM
Absolutely.
I had a weird issue with my purple truck where the fuel solenoid was working fine but the little keyway on the shaft had fallen out so sometimes the truck would struggle to start, then fail to shut down because the little cam piece was slipping on the valve pump shaft.
One time right before I figured this out I was towing a customers little runabout and the truck felt like it was struggling everywhere I went. had my foot to the floor and it was just gutless. I thought the solenoid was failing so I pulled over, unplugged the solenoid and zip tied it up. Still gutless and ran terrible, managed to make it home, couldn't pull the boat up the driveway, truck just had nothing there, imagine my surprise when I cut the zip ties and the truck stayed idling as the solenoid snapped down to the shutdown position.
I'd strongly suggest looking over everything long before replacing the IP
Red Truck: 97 2500 4x4 ECLB 250k-ish, mostly stock.
Purple Truck: 01 1500 4x4 ECSB 12v Conversion, has all the 1996 3/4 ton stuff besides the body at this point.
JarodTLG is offline
post #3 of 39 (permalink) Old 06-11-2019, 06:41 PM
Moderator
9297oldram's Avatar
Check to be sure the FSS is opening all the way up? When you bled the filter after replacing it did the LP push the fuel out like it was supposed to?
Did you check the turbo shaft? How about the air filter?
9297oldram is offline
post #4 of 39 (permalink) Old 06-11-2019, 06:58 PM
Antonm's Avatar
Mine blew the boost reference line off the back of the AFC once and that made the truck just gutless until I figured it out (on the side of the road). Check the little plastic line going to the back of the AFC and make sure its hooked up to a good boost reference.
97 Extended cab 4x4, NV4500, valair single disc clutch, 4k gov springs, +60 lb valve springs, homemade #10 plate, medium tension AFC spring, flat washers AFC diaphragm, stock turbo and injectors, lifted on 37" tires with re-stacked limited slip friction plates, and factory 4:10 gears.
Antonm is offline
post #5 of 39 (permalink) Old 06-11-2019, 07:38 PM Thread Starter
Ok guy thanks for the help if you guys think of anything else let me know. The guy wanted 4000 bucks to replace the injection pump. The guy that look at it before said it had 30psi fuel pressure. Turbo spins free and check air filter. I know it's going to be something dum wrong with it. Truck is pretty rusty under the hood.
post #6 of 39 (permalink) Old 06-11-2019, 07:46 PM
GAmes's Avatar
iTrader Score: 7 reviews
This happened to me a week ago. A little hard to start, needed pedal to get going, very low power but would free rev to 2600 easily. I carry a spare, this has happened to me before. Fixed in 30 minutes.
JarodTLG likes this.
GAmes is offline
post #7 of 39 (permalink) Old 06-11-2019, 07:46 PM
Moderator
9297oldram's Avatar
I've seen the FSS rusty on the pump end and wouldn't let it open all the way.
post #8 of 39 (permalink) Old 06-11-2019, 09:00 PM Thread Starter
I wont get to look at it till the weekend. . That will be the first thing I check will be the shut off.
post #9 of 39 (permalink) Old 06-11-2019, 09:21 PM
Loud Pedal's Avatar
I'm waiting till you write your memoirs (a book)...I'll be at the front of the line to buy and get a signed autograph....
dd453ford likes this.
98-4x4 5spd
Loud Pedal is online now
post #10 of 39 (permalink) Old 06-11-2019, 09:32 PM
GAmes's Avatar
LOL. One only need to read this forum and the TDR to get my truck history. I'm too lazy to collate it. The FSS broke the morning after we had met for beer.
GAmes is offline
post #11 of 39 (permalink) Old 06-12-2019, 08:07 AM
Antonm's Avatar
If you've experienced multiple broken solenoids, why not go the pull cable route and eliminate it all together? Wouldn't be any need to carry a spare then.
Antonm is offline
post #12 of 39 (permalink) Old 06-12-2019, 08:31 AM
GAmes's Avatar
Two in 22 years and almost 1.4 million miles does not constitute "multiple". In case you aren't aware, cables break and fittings come apart. Besides, I don't want to hack up my dash, drill a hole in the firewall, find a route for the cable and end up with a disfigured interior.
k9american and jake97/12valve like this.
GAmes is offline
