AFC shaft o-rings - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-07-2019, 12:41 PM Thread Starter
Antonm's Avatar
AFC shaft o-rings
A few weeks ago I pulled my AFC off to install a lighter spring and do the flat washer/ foot grind mod. The O-ring on the shaft looked pretty bad (over 20 years old, flat and hard) so I pulled it off and it broke in the process. I have several O-ring kits in metric & sae but none of them had a good replacement. I ended up putting two o-rings in the groove that had the correct ID & OD but a way smaller cross section (hence two of them actually fit in the groove.
Long post to say, does anyone know where I can get replacement O-rings for the AFC shaft? I tried the regular websites (Geno's, PDP), searching google and this forum, still could find them.
97 Extended cab 4x4, NV4500, valair single disc clutch, 4k gov springs, +60 lb valve springs, homemade #10 plate, medium tension AFC spring, flat washers AFC diaphragm, stock turbo and injectors, lifted on 37" tires with re-stacked limited slip friction plates, and factory 4:10 gears.
Antonm is offline
post #2 of 6 (permalink) Old 06-07-2019, 12:53 PM
Kryp2nitE's Avatar
Do you have a picture of where they go?
95 2WD 47RH
Kryp2nitE is offline
post #3 of 6 (permalink) Old 06-07-2019, 02:15 PM Thread Starter
Antonm's Avatar
Not my picture (got it off google image search) , but this is the O-ring I need.
Antonm is offline
post #4 of 6 (permalink) Old 06-07-2019, 02:31 PM
Kryp2nitE's Avatar
I canít find a part list the goes with this but o bet a local Bosch shop can get you the part with the picture
95 2WD 47RH
post #5 of 6 (permalink) Old 06-07-2019, 02:46 PM Thread Starter
Antonm's Avatar
Looks like I need piece 24 from the explode view. This shouldn't be complicated , its an O-ring that sees maybe 40psi and not that much heat. Any regular rubber O-ring the right size should work (although I would prefer a viton) . Beside the fact there isn't a local Bosch shop anywhere close to me, I'd imagine that Bosch would charge something like $30 for one O-ring. There has the be a source online, hell, you can order brides from Russia online, surely an O-ring can be found.
Antonm is offline
post #6 of 6 (permalink) Old 06-07-2019, 09:39 PM
Truefat's Avatar
There shouldn't be any real pressure there at all. The pressure is on the other side of the diaphragm. If your dual o-ring fix isn't leaking any oil then I think you're good.
1998 2500HD Laramie SLT 4x4 12v QCSB 5 spd 3.55 200k stock
2004 2500 Laramie 2wd 305hp QCSB 6spd 3.73 200k stock
Truefat is offline
