12v in tank fuel pump vs 24v pump - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-01-2019, 07:43 PM Thread Starter
My 1998 12v’s in tank fuel pump recently started leaking and not reading correctly and has started to break in multiple spots. So I found a pump online and I received it I realized it was the 24v model. Can I still use it or are their problems with that. Thanks everyone who can help
H Cook is offline
post #2 of 6 (permalink) Old 06-01-2019, 08:11 PM
9297oldram's Avatar
A 12v doesn't have a intank fuel pump, the fuel pump is located on the side of the engine.
9297oldram is offline
post #3 of 6 (permalink) Old 06-01-2019, 09:50 PM
lake huron cummins's Avatar
Unless there was an update done to it. My 99 24v had a TSB done to it that put the fuel pump in the tank due to the one on the block being a pos.
The in tank model will work just fine unless you have fueling mods done to the engine, bigger injectors, pump turned up, etc. Than the in tank model cant sensor enough fuel to the injection pump and you'll burn it up.
99 2500 q/c 4x4 in restoration state.
https://www.cumminsforum.com/forum/9...sto-build.html
2015 Silverado 3500HD C/C Dually LTZ Dmax/Ally bone stock, MagHytec double deep trans pan, AAM finned rear diff cover, B&W Companion
2017 Northpoint 375BHFS
lake huron cummins is offline
post #4 of 6 (permalink) Old 06-01-2019, 10:08 PM
GAmes's Avatar
iTrader Score: 7 reviews
Incorrect. First, there was never an update to put a 12 valve lift pump in the tank. Second, a 24 valve pump does not produce enough pressure to feed a p-pump.
Op, you need one of these. There are numerous threads about it, AND the info is in what should be the most used tool in the shop, a factory service manual.
https://www.genosgarage.com/product/...kit/fuel-pumps
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is online now
post #5 of 6 (permalink) Old 06-01-2019, 10:35 PM
Truefat's Avatar
Sounds to me what you are looking for is the sending unit
https://www.genosgarage.com/product/...ank-components
1998 2500HD Laramie SLT 4x4 12v QCSB 5 spd 3.55 200k stock
2004 2500 Laramie 2wd 305hp QCSB 6spd 3.73 200k stock
Truefat is offline
post #6 of 6 (permalink) Old 06-01-2019, 11:49 PM
GAmes's Avatar
My apologies, Truefat is correct. You don't need a lift pump, you need a tank module, maybe. Have you confirmed the module is leaking or just a fuel line? Unfortunately, from what I have read, the '96-'97 module won't work on a '98. A bit more info if you sort out the confusion.
https://www.turbodieselregister.com/...ke-fix.266579/
GAmes is online now
