Freeing stuck exhaust brake - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 18 (permalink) Old 06-03-2019, 07:51 AM Thread Starter
alanack6795's Avatar
Originally Posted by GAmes View Post
Originally Posted by alanack6795 View Post
Truck runs well, and i aquired it for free, im going to fix it up.
Everyone on this forum is jealous.
Its a good truck but it needs a lot of work. I think its cool because it has all the 90s and early 2000s aftermarket parts. Truck looks like its out of a tdr magazine. He custom ordered it new, his name is on the window sticker.
alanack6795 is offline
post #14 of 18 (permalink) Old 06-03-2019, 08:06 AM
toms73novass's Avatar
Location: Grand Island, NY (Between Buffalo and Niagara falls)
I had a Pacbrake that was under the truck, froze solid, took apart many times lubed with their oil. I had vbands on each end to make it easier to remove and lube. Finally Froze solid, no matter what I did it would not free up, took it off and trashed it.
'98 QCSB 4x4 12v , G56 with Valair DD !!! , Full set of gages... 5x.014 DFI injectors, 4k gsk he351 60x60x9, S472 72mmx83mm 1.1 ratio. Twins, 0 plate... Carli 2.0 Suspension, Firestone Air bags.
toms73novass is offline
post #15 of 18 (permalink) Old 06-03-2019, 09:12 AM Thread Starter
Havent heard from you in a while. Welcome back!
Hopefully i have better luck. Another memeber said ill have to pull it apart and clean it, i think hes right
post #16 of 18 (permalink) Old 06-03-2019, 09:15 AM
Had issue with account and never got response for password stuff, finally made time
truck still runnin' strong
BrooksAD likes this.
post #17 of 18 (permalink) Old 06-04-2019, 08:25 PM
BrooksAD's Avatar
Throttle body cleaner
You know, I've been having some issues with my exhaust brake being stuck for quite a while. I've been in here researching and have had quite a few good suggestions but nothing has helped yet. Short of pulling my turbo apart (which may be a different animal from yours) I have done most things that should help but I just haven't freed it up yet. I have an '08 6.7L, BTW.
Anyway, I happened to be at the dealer a few weeks back picking up a new battery box and mentioned this problem. They sold me a can of Mopar Throttle Body Cleaner and said that would loosen up and free my actuator problem. Unless you're dealing with rust down in there, this might be helpful. Just a suggestion w/o knowing more.
BrooksAD is offline
post #18 of 18 (permalink) Old 06-05-2019, 10:19 AM Thread Starter
Tried moving the acuator by hand, nothing and some light tool work still nothing.
Didnt hit with oil yet, but its probably coming apart.
