Identifying vacuum/electrical device - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 05-30-2019, 06:43 PM Thread Starter
1996 D3500 2wd manual trans. On the drivers side inner fender, there is a square device with an electrical connector in the side and a vacuum port out the top. Mine has the vacuum port cracked. What is it? There's a remnant of a part number on it but it's illegible. Here's a pick...it's on the far right and has a rusty looking base on it with a hose out the top secured by a wire clamp. By the way, this is not my engine compartment.
Thanks!
tenxal is offline
post #2 of 7 (permalink) Old 05-30-2019, 07:01 PM
The Uppity 12v Guy
dauntless89's Avatar
It's a switch that illuminates the brake warning idiot light on the dash when vacuum is low.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is online now
post #3 of 7 (permalink) Old 05-30-2019, 10:24 PM
Armchair Mechanic
colin91's Avatar
Low vacuum warning switch. No longer made or available anywhere that I have found. Vacuum port/nipple cracked off mine as well awhile ago. Without being able to find a good replacement I shoved a brass barb in the hole best I could and then put JB Weld around it to seal it up and make it sturdy. Been working fine that way for 5+ years.
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped, Crowler Springs, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
post #4 of 7 (permalink) Old 05-31-2019, 09:46 AM
Why is there a tube going to your top shock bolt
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #5 of 7 (permalink) Old 05-31-2019, 10:30 AM Thread Starter
Not my engine compartment....pic is for purpose of identifying the vacuum switch.
tenxal is offline
post #6 of 7 (permalink) Old 05-31-2019, 04:45 PM
9297oldram's Avatar
I just put a vacuum gauge in the end of mine so I could check to see what my vacuum was.
9297oldram is offline
post #7 of 7 (permalink) Old 06-05-2019, 10:46 PM Thread Starter
Update: the vacuum hose nipple was cracked and leaking vacuum. I drilled out the hose hipple area on the switch and epoxied a brass nipple in. Works great, solved the ABS/Brake warning light issue.
tenxal is offline
