Oil pan gasket - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By GAmes
post #1 of 11 (permalink) Old 05-27-2019, 06:51 AM Thread Starter
ekvhekvh's Avatar
I have transmission out and flex-plate off, will be installing a billet flex-plate.
Can I replace the pan gasket now without raising the motor? I probably should reseal the oil cooler and vacuum pump while there.
Any other suggestions while there?
I just did front cover and seals.
Thanks in advance
96 Ram 2500 4x4 automatic. Engine number: ??? Missing.
ekvhekvh is offline
post #2 of 11 (permalink) Old 05-27-2019, 11:42 AM
blackDOHC's Avatar
You'll still need to lift the motor to lower the pan enough to drop the pickup tube inside. I replaced my oil pan when my trans was out and it still wasn't a fun day.
1997 ECLB - 5" Diamond Eye straight pipe - ISSpro Trans temp/EGT/Boost - AFC Live - boost elbow - 191s - Built trans - BHAF - ARP 425s - PSC SG852 - 315/75/16
blackDOHC is offline
post #3 of 11 (permalink) Old 05-27-2019, 01:27 PM Thread Starter
ekvhekvh's Avatar
Went and looked again, not going to be fun.
ekvhekvh is offline
post #4 of 11 (permalink) Old 05-27-2019, 02:23 PM
alanack6795's Avatar
Take the rear adapter plate off, it will be easier. Just jack the motor up by the crank pulley.
Hardest part is dropping the pick up tube into the oil pan
alanack6795 is offline
post #5 of 11 (permalink) Old 05-27-2019, 11:40 PM Thread Starter
ekvhekvh's Avatar
“Just jack the motor up by the crank pulley.”
Not following that. You mean just rock it or let it slide up in the motor mounts?
When do you look at bearings? Mine has 225k
ekvhekvh is offline
post #6 of 11 (permalink) Old 05-28-2019, 08:29 AM
GAmes's Avatar
iTrader Score: 7 reviews
He means you can put the jack under the crankshaft pulley. I prefer to lift it from the top with a hoist. The one time I did mine I disconnected the hoses into the inlet and out of the turbo. Removed #5 & 6 valve covers and covered the rockers to keep debris out, disconnected the exhaust downpipe and removed the fan. The engine will lift quite a ways up with those things disconnected. Loosen the bolts that are through the motor mounts enough for them to slide up the grooves. I also backed off the transmission mount bolts a bit. Once lifted I suggest you put blocks under the motor mounts in case the lifting device fails.
98whitelightnin likes this.
GAmes is offline
post #7 of 11 (permalink) Old 05-28-2019, 12:05 PM Thread Starter
ekvhekvh's Avatar
That makes sense, thanks for clarification.
ekvhekvh is offline
post #8 of 11 (permalink) Old 05-28-2019, 02:39 PM
The engine leans forward without the trasmission, but it's still pretty balanced, you can actually lift it by hand.
I didnt need to remove the valve cover but it probably would have been easier.
post #9 of 11 (permalink) Old 05-28-2019, 07:50 PM
GAmes's Avatar
My transmission was still connected, obviously.
GAmes is offline
post #10 of 11 (permalink) Old 05-28-2019, 08:06 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
I pretty much did it the way GAmes did and had no problems. I also left the pickup tube in place.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #11 of 11 (permalink) Old 06-06-2019, 11:10 AM
Used a cherry picker to lift the front of mine all the way to the top. Wasn't a big deal.
FYI new CUMMINS gasket was 4 piece - I didn't like that. When I started to tighten the bolts (in proper order), the gasket wanted to squeeze out. I would use either a one piece, OR a Mahle gasket. From my recent experience.
spawn_x is offline
Similar Threads
68RFE Transmission pan gasket? dave_in_az 07.5 - 09 3rd Gen 6.7L Powertrain 4 05-03-2019 07:39 PM
oil pan gasket gasket manufacture ethan169 3rd Gen. Powertrain 10 06-24-2014 07:52 PM
2011 head gasket.... marshallc 4th Gen Powertrain 32 05-19-2012 08:19 AM
felpro head gasket ok? big price difference.. 93ford 94-98 Performance Parts Discussion 41 04-03-2012 01:58 PM
Rocker Box Gasket/Valve Cover Gasket Stovetop535 3rd Gen. Powertrain 5 03-23-2011 10:44 PM
