Surging issue please help - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 18 (permalink) Old 05-27-2019, 07:05 PM
I think that's a fine idle but as it was mentioned its personal preference. You'll find it will drop a little of the ambient temp is high (100+) or if it's cold out.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #14 of 18 (permalink) Old 05-31-2019, 03:15 AM
I set my idle a touch higher, the brakes are better with more vacuum, starts better too, less cold idle haze as well. Set it where you like it.
1994 single cab 4x4 2500 auto, black linex premium covering entire truck, rear frame blasted and por15'd, Firestone airbags, 35" good years, 3/4" spacers, longer rear wheel studs.
Charlie Brown is offline
post #15 of 18 (permalink) Old 05-31-2019, 05:14 AM
aviomech's Avatar
Originally Posted by hemirunner426 View Post
Looking at the tach and the sound of the engine tells me the idle is way too low. The tach is not 100% accurate but you want to be somewhere above the last line before the 1k mark.
The engine will surge if idle is too low. Basically the governor can't properly regulate fueling below its rated RPM.
Nailed it! I was going to respond to this. I used to rebuild P-pumps, and seen a few pumps if adjusted properly, could have remained in service. If the timing and idle get adjusted on these pumps after they wear in, you can keep them in service a bit longer.
aviomech is offline
post #16 of 18 (permalink) Old 05-31-2019, 09:40 AM
GAmes's Avatar
iTrader Score: 7 reviews
Tickled by this. My theory is if you refrain from junk "alternate fuels" (atf, used motor oil and 2SO), and only use a fuel additive for anti-gel the "bit longer" amounts to nearly 1.4 million miles and still counting.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
The Following User Says Thank You to GAmes For This Useful Post:
aviomech (05-31-2019)
post #17 of 18 (permalink) Old 05-31-2019, 11:33 AM
aviomech's Avatar
WOW! I'd love to make that mile marker!
I'd say 90% of the pumps I rebuilt were due to dirty fuel. Plungers and barrels would look like 40 grit sand paper was used on them. I cannot preach enough about using a quality fuel filer and good, clean fuel.
hemirunner426 likes this.
aviomech is offline
post #18 of 18 (permalink) Old 06-06-2019, 11:56 PM Thread Starter
dieselsyndicate's Avatar
its fixed now idle adjustment worked. and fuel filter was dirty
1997 california 12 valve cummins
mods so far... egr delete, coi, stock exhaust straight piped... list will expand
https://www.instagram.com/dieselsyndicate/
dieselsyndicate is offline
Similar Threads
Radio Issue, Remote Start Issue, Power lock issue bunkysdad 2013-2018 General Discussion 5 04-07-2018 03:21 PM
48re shift issue Tech394 3rd Gen. Powertrain 6 10-14-2017 11:24 AM
Urgent HELP needed with 5.9L Cummins issue TDMoby 911 Urgent Situations 14 02-07-2014 02:02 PM
Rough shudder issue *Warning Long Post* ETS 07.5 - 09 3rd Gen 6.7L Cab & Chassis 57 04-04-2012 12:39 AM
Need some insight on surging issue GreenDrake 98.5-02 Powertrain 1 09-03-2011 10:39 AM
