Head Bolts - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 05-23-2019, 06:21 PM Thread Starter
Head Bolts
Hello Gents,
Pulled my head due to a knock investigation. Pistons looked good and cylinders looked perfect so I put the head back on with new gasket and NEW head bolts.
Well the knock still had me worried so I decided to pull the motor to put in new bearing and rings etc.
The new head bolts I put on a month ago were torqued, only run less than 30 minutes (not even driven with)
Is it safe reuse the head bolts since they didn't go through any heat cycles, just the initial torque?
Any input is greatly appreciated.
holmanrd is offline
post #2 of 3 (permalink) Old 05-23-2019, 11:13 PM
myother4x4isaCJ7's Avatar
Did your gasket kit come with a head bolt stretch gauge? If they are under a certain length they are good to use. That being said if you didnít overtorque the heck out of them your probably fine.
myother4x4isaCJ7 is offline
post #3 of 3 (permalink) Old 05-24-2019, 11:32 AM Thread Starter
Thank you myother4X4isaCJ,
I totally forgot about the bolt stretch gauge that was with my gasket kit from when when I pulled the head.
holmanrd is offline
Similar Threads
Bore distortion: headstuds and head bolts chknkatsu 2013-2018 General Discussion 17 10-25-2018 02:34 AM
re-torqueing head bolts? or studs? scotty12v 94-98 Powertrain 39 08-16-2017 08:13 AM
Shop Call Out- Q&A Head Gasket Failure and Stud Install KMKDIESEL 4th Gen Performance Parts Discussion 1 08-07-2017 11:31 PM
Head bolts yielding? NotSoNicely 98.5-02 Non-Powertrain 13 03-30-2017 12:57 PM
Head Studs vs Bolts 12 valves of power 94-98 Performance Parts Discussion 24 11-22-2011 10:02 PM
