Truck randomly dies, then starts fine. - Page 5 - Dodge Cummins Diesel Forum
 4Likes
post #49 of 70 (permalink) Old 06-03-2019, 02:22 PM
Truefat's Avatar
I think if plungers are sticking there would be scuff marks on the barrels. Is it possible to visually examine the barrels with the delivery valves out?
You should also try to confirm that the pump is a 180 and not a 160. It could have been swapped.
1998 2500HD Laramie SLT 4x4 12v QCSB 5 spd 3.55 200k stock
2004 2500 Laramie 2wd 305hp QCSB 6spd 3.73 200k stock
Truefat is offline
post #50 of 70 (permalink) Old 06-03-2019, 11:38 PM
GAmes's Avatar
iTrader Score: 7 reviews
Originally Posted by Guss101 View Post
When it happens it sounds like itís not running on all cylinders. I thought it was maybe air in the fuel to begin with but it sounds more like itís dropping a cylinder or two. Iím green with this stuff so I may not be explaining the symptoms well enough
Not running on all cylinders is a lot different than randomly dieing. It would be great if you were consistent and accurate in the description. Pressure dropping to zero when you shut it off is normal.
dd453ford likes this.
GAmes is online now
post #51 of 70 (permalink) Old 06-04-2019, 12:15 AM Thread Starter
Guss101's Avatar
When it happens it sounds like it’s not running on all cylinders. I thought it was maybe air in the fuel to begin with but it sounds more like it’s dropping a cylinder or two. I’m green with this stuff so I may not be explaining the symptoms well enough
GAmes I really appreciate your help, I know you are very knowledgeable, I on the other hand am not. I’m self taught 90% of that is from reading on here. Reading and writing are not my strong suit, hence my low post count. None the less I’m trying to give full and accurate information to the best of my knowledge. Yesterday it dawned on me that it sounded more like loosing a cylinder, again learning as I go. Sorry for the confusion
79 D200 crewcab converted to w200, 97 12v nv4500. 09 lariat seats, need cash to finish
Guss101 is offline
post #52 of 70 (permalink) Old 06-04-2019, 02:34 PM Thread Starter
Guss101's Avatar
I think I’m going to get my pump checked out, not sure what else. I don’t have money to throw around but if it fixes something then good and if not at least it’s been gone through and balanced. I need to get this thing totally reliable, wife’s loosing a little bit of faith lol.
I’m planning to go through diesel Tuff , unless someone has serious suggestions for guy in western Canada
Guss101 is offline
post #53 of 70 (permalink) Old 06-04-2019, 03:16 PM
Truefat's Avatar
I think Iím going to get my pump checked out, not sure what else. I donít have money to throw around but if it fixes something then good and if not at least itís been gone through and balanced. I need to get this thing totally reliable, wifeís loosing a little bit of faith lol.
Iím planning to go through diesel Tuff , unless someone has serious suggestions for guy in western Canada
Did you check the hose between the prefilter and pump?
Truefat is offline
post #54 of 70 (permalink) Old 06-05-2019, 11:26 AM Thread Starter
Guss101's Avatar
I did, couldn’t find any signs of it leaking, didn’t look cracked or any wet spots anywhere, but I’ll replace it just cuz it’s old and simple to do. Plan on pulling the pump this week. Hope I can report back that I made the right call lol
Thanks everyone for your suggestions and help.
Guss101 is offline
post #55 of 70 (permalink) Old 08-01-2019, 07:26 PM
I was wondering if there was a solution to this problem I believe I am experiencing similar. Out of no where truck died driving down road when I came to stop. I have 5 speed and can feel truck not want to accelerate and when I push clutch in it died instantly. I can restart the truck while holding throttle down but now without. What is strange is after I fill up it is fine for a while till about a quarter tank. First day it did it I filled up and drove another almost 200 miles. To a job about 2 hours away it was hot so I let it idle for almost an 45-1hr it had no issues starting without throttle and ran great. Then hop in and truck dies as soon as I get up to the first light on highway after getting up to speed. I was able to make it to fuel up past half tank and did not do it for next 75 miles or 1.5 hour drive. I have 25 psi fuel pressure unless wot then got down to 15. I know I’m lacking fuel however this does not happen wot and has over 20 psi when dies. I installed new lift pump, I have the torq tek ofv 75 horse injectors 4K gsk truck has 225,000 miles. I have messed with the connections to fsv after I filled up and ran fine. Other than it dying truck runs great even with 2 welders and utility body filled with tools she moves no problem. The truck is 95 cab and chassis 2wd with solid front axle. I have looked and looked all over the internet with no success as seems everyone else has issues with the truck running poorly. Thank you for any responses.
1995 3500 single cab flat bed, SB 750 hp dd clutch, 6" stacks, 4k gov springs, afe drop in filter. No fuel plate. ddp 75hp injectors. 218,000 miles
burntice is offline
post #56 of 70 (permalink) Old 08-01-2019, 09:30 PM
GAmes's Avatar
Originally Posted by burntice View Post
I was wondering if there was a solution to this problem I believe I am experiencing similar. Out of no where truck died driving down road when I came to stop. I have 5 speed and can feel truck not want to accelerate and when I push clutch in it died instantly. I can restart the truck while holding throttle down but now without. What is strange is after I fill up it is fine for a while till about a quarter tank. First day it did it I filled up and drove another almost 200 miles. To a job about 2 hours away it was hot so I let it idle for almost an 45-1hr it had no issues starting without throttle and ran great. Then hop in and truck dies as soon as I get up to the first light on highway after getting up to speed. I was able to make it to fuel up past half tank and did not do it for next 75 miles or 1.5 hour drive. I have 25 psi fuel pressure unless wot then got down to 15. I know Iím lacking fuel however this does not happen wot and has over 20 psi when dies. I installed new lift pump, I have the torq tek ofv 75 horse injectors 4K gsk truck has 225,000 miles. I have messed with the connections to fsv after I filled up and ran fine. Other than it dying truck runs great even with 2 welders and utility body filled with tools she moves no problem. The truck is 95 cab and chassis 2wd with solid front axle. I have looked and looked all over the internet with no success as seems everyone else has issues with the truck running poorly. Thank you for any responses.
If the problem only occurs after you are below a certain point on the fuel gauge has it ever crossed your mind that there might be a hole in the fuel pickup hose inside the fuel tank?
BTW, 75 horse injectors has no meaning. Number of holes, hole size and spray angle is how injectors are identified i.e. 5X12 45 degrees There is no telling what you have, not that it makes a difference in this problem.
GAmes is online now
post #57 of 70 (permalink) Old 08-01-2019, 09:56 PM
Yes checking the tank was my next step I was just hoping I did not have to, and I apologize for the 75hp injectors I purchased them off of the market place listed as 75 hp injectors. I appreciate your input and hopefully can find some time this weekend to check that out.
burntice is offline
post #58 of 70 (permalink) Old 08-02-2019, 11:28 AM
GAmes's Avatar
I try to avoid sellers who prey on potential customers lack of knowledge. They either don't know themselves or they are too lazy to pass on a little knowledge for education sake. Obviously, an injector installed on a 160 HP engine will give more of a power gain than if they are installed in a 215 HP engine. It is a crapshoot of actual HP increase, in either engine.
GAmes is online now
post #59 of 70 (permalink) Old 08-02-2019, 11:40 AM
alanack6795's Avatar
Factory 215s are often labled as 40hp injectors. They probably wont add 40hp to a 215 o 180 truck. Maybe on a 160 truck.
Hp ratings are useless
alanack6795 is offline
post #60 of 70 (permalink) Old 08-02-2019, 02:35 PM Thread Starter
Guss101's Avatar
No solution yet, I haven’t been under the hood in a long time. Busy with work, and rodeos this summer. Should be home this weekend, first time since beginning of June. Hope to get the pump pulled and sent off. See what the pros say 🤷‍♂️
Guss101 is offline
Similar Threads
04.5 starts then dies. Need ideas 79malibuguy 3rd Gen. Powertrain 4 05-19-2017 08:44 AM
'05 Cummins, Idles Fine, Starts Fine, Slow to Rev & No Power never_summer_ind 3rd Gen. Powertrain 20 01-07-2017 01:38 PM
truck dies randomly humincumin 94-98 Powertrain 0 02-01-2014 05:49 PM
99 Dodge 2500 Dually - Idles Fine Dies In Gear - Help!!! TransAmMike 98.5-02 Powertrain 3 01-13-2014 10:30 AM
2006 rough starting then dies then starts again then runs fine? Grosser397 3rd Gen. Powertrain 3 03-09-2013 07:42 PM
