12v valve stem (old style) seals slipping off head - Dodge Cummins Diesel Forum
 1Likes
post #1 of 19 (permalink) Old 04-30-2019, 06:42 PM Thread Starter
Hey everyone. So while doing my 60lb valve springs i decided to replace all 12 valve stem seals. I got Mahle 216-1114 seals. The entire job went straight forward. Used a correctly sized socket and a little mallet and lightly tapped the seals down onto the head. I made sure the seals were lubed up so they didn't tear. About a week later I pulled the valve covers to check on things and noticed on cylinders 1,3,4, all 6 valve stem seals lifted off the head and were riding around on the valve. I tore it all back apart one cylinder at a time and reseated the seals on the head. Next day, same deal. 6 seals lifted off the head. Any help or suggestions? Thank you!
5912valve is offline
post #2 of 19 (permalink) Old 04-30-2019, 07:04 PM
GAmes's Avatar
iTrader Score: 7 reviews
You lubed the seals and expected them to stay put? I recommend you install them dry.
GAmes is offline
post #3 of 19 (permalink) Old 05-01-2019, 08:54 AM
GAmes's Avatar
Since they are now stretched out a dab of thread locker on each one won't hurt.
GAmes is offline
post #4 of 19 (permalink) Old 05-06-2019, 04:06 PM Thread Starter
I brake cleaned everything and used a little loctite on the seals, let it dry, put it all back together and the same ones that slipped off before, slipped off again. I’m at a loss
post #5 of 19 (permalink) Old 05-06-2019, 04:28 PM
myother4x4isaCJ7's Avatar
Originally Posted by 5912valve View Post
I brake cleaned everything and used a little loctite on the seals, let it dry, put it all back together and the same ones that slipped off before, slipped off again. Iím at a loss
If your head is worn and valve stem clearance is excessive boost/drive pressure will pop the seals up eventually.
myother4x4isaCJ7 is offline
post #6 of 19 (permalink) Old 05-07-2019, 09:43 AM
Location: Tennessee, on a twisty road north of Smashville
I had my head machined for the new 'top-hat' style seals due to this issue. Sure, it doesn't happen to most folks, but I wanted the reliability.
thor363 is offline
post #7 of 19 (permalink) Old 05-07-2019, 04:36 PM Thread Starter
Was the machining required for the new seals? What year 12 valve?
post #8 of 19 (permalink) Old 05-09-2019, 09:03 AM
1995 12 valve and yes the valve guide area needs to be cut down to accommodate, but it wasn't much to do. Had the entire head ported mildly to unshroud below the valves and the guides cut for the new seals, as well as valve job for 500 if I recall correctly. Reassembled with new springs, seals, and retainers/keepers.
thor363 is offline
post #9 of 19 (permalink) Old 05-21-2019, 07:26 AM
afterburn549's Avatar
Ideas-
Dont drop the valve when you do this but check the valve to guide clearance.
I would guess there is a high degree of wobble going on?
OR, Maybe -
you have the wrong size / style of stem seals for the guides.
98.5 1 ton Dually -Engine balanced, 275 HP Inj. Ceramic topped pistons with Molly skirts
Mercedes 6 speed, air bags on rear.
Gauges, steel piston squirters
afterburn549 is offline
post #10 of 19 (permalink) Old 05-21-2019, 01:58 PM
k9american's Avatar
PDD has a recent video about 60# springs, retainers and locks. They also stock the top hat seals. I saw their video of those seals and don't recall hearing anything about machining the head. I'll have to look for that again. Could be wrong. I'd post links but don't think that's allowed.
'96 2500 4x4 NV4500, boost/pyro, kdp, stock plate fwd, CAI, 4" exhaust, Bilstein shocks, 195k mi. Y->T steering upgrade, SB clutch, etc.
k9american is offline
post #11 of 19 (permalink) Old 05-21-2019, 05:13 PM
GAmes's Avatar
Videos and links to videos are posted every day.
GAmes is offline
The Following User Says Thank You to GAmes For This Useful Post:
k9american (05-21-2019)
post #12 of 19 (permalink) Old 05-21-2019, 06:04 PM
The Uppity 12v Guy
dauntless89's Avatar
Top hat seals don't drop on to factory heads. The stem seal boss needs to be machined but you can do it with a cordless drill and a special cutter with the head off the engine.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
Similar Threads
Valve adjustment, oil seals in head? promisedlandorganicfarmer 3rd Gen. Powertrain 16 10-04-2016 06:17 PM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
valve stem seals mowerracer828 98.5-02 Performance Parts Discussion 4 08-20-2014 12:36 PM
head studs and valve seals oldmansimek 94-98 Performance Parts Discussion 12 06-11-2013 04:19 PM
changing valve stem seals... CumminsGermany 3rd Gen. Powertrain 2 03-10-2011 01:23 AM
