94 4x4 Auto Stalling When Put Into Gear When Not Warmed Up - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By tdp_julian
post #1 of 10 (permalink) Old 04-20-2019, 11:46 AM Thread Starter
94 4x4 Auto ran perfect until one day had to use the 4x4. Then about 15 minutes of driving I came to a stop and the truck starts surging and wanting to die at the light. 5 minutes later the truck actually started to die. I figured it was the TC staying locked in killing the truck. Fast forward to a few weeks later ive replaced the lift pump and the fuel shut off solenoid and turned up the idle a little to where its about 850 rpms. Issue is before I had all these issues the truck ran perfectly with no issues now it wants to die if the truck isn't warmed up warmed up! TC doesn't feel locked up anymore and truck drives normal when warmed up. (no shifting issues or OD issues). Fuel filter is pretty new I haven't replaced the heater bowl screen yet and it has a goerend single disk in it that's almost new. Where should I start? Any help or suggestions would be appreciated!
tdp_julian is offline
post #2 of 10 (permalink) Old 04-20-2019, 12:17 PM
Moderator
9297oldram's Avatar
Did you recently get fuel?
9297oldram is offline
post #3 of 10 (permalink) Old 04-20-2019, 01:15 PM
What stall is the TC?
2001 Dodge 2500. Short bed, extended cab. 2wd.
1969 chevy c-10. 502 crate engine.
1969 chevy camaro. real z-28
dohyde34 is online now
post #4 of 10 (permalink) Old 04-20-2019, 01:47 PM Thread Starter
Yes but I've ran a couple of tanks since all of this happened! I run diesel Kleen every tank. No idea on the stall but I can give you a part number?
post #5 of 10 (permalink) Old 04-20-2019, 02:04 PM
Moderator
9297oldram's Avatar
I'd change the filter again and dump the contents into a clean container to see if there's water in it.
If your torque converter was staying locked in you'd know it if you was to run it hard, the shifts would set you back in your seat
post #6 of 10 (permalink) Old 04-20-2019, 06:45 PM
What's the idle in gear with AC on? 850?
If so, next time it starts dying throw a couple gallons of cold water on the IP. If the engine clears up then it's time to start thinking about an IP.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #7 of 10 (permalink) Old 04-22-2019, 03:33 PM
2Nubs's Avatar
Idle in gear, AC on=750rpms
Once warm, in neutral or park, it will be just below 1000rpms.
'95 Cummins
2Nubs is offline
post #8 of 10 (permalink) Old 04-22-2019, 04:14 PM
Try the cold water trick next. The early 160 pumps have an issue chewing up barrels & plungers after XXXX amount of heat cycles. It's the easiest thing to check off right now before you start doing further diagnostics.
post #9 of 10 (permalink) Old 04-25-2019, 08:55 PM Thread Starter
Ended up changing the lift pump, while I was there I figured I'd change my pre screen and looky here! Runs like a brand new truck again!
hemirunner426 likes this.
post #10 of 10 (permalink) Old 04-25-2019, 09:41 PM
GAmes's Avatar
iTrader Score: 7 reviews
Could have saved $100 and a few hours by checking the screen first. You even mentioned it in your first post.
Edit; Aggie, that explains it.
GAmes is online now
Similar Threads
06 auto gear swap derek06 3rd Gen. Powertrain 13 01-10-2016 02:24 PM
Loading up at idle in gear, stalling hot rod4 911 Urgent Situations 5 11-03-2011 02:34 AM
Truck stalling when put in gear Chumscrubber 98.5-02 Powertrain 2 05-27-2011 11:24 AM
Trans issue (No O/D or Reverse) justacummins 98.5-02 Powertrain 8 01-24-2011 02:23 PM
Auto trans, New Process Gear?? africancoalminer 98.5-02 Powertrain 2 12-26-2010 09:19 AM
