47re to replace 47rh - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 04-11-2019, 10:43 PM Thread Starter
JLD
47rh Tranny went out in my 95 2wd. I found a super deal on a 47re for a 2001 4x4. Would it be possible to make this tranny work in my 95
JLD is offline
post #2 of 12 (permalink) Old 04-11-2019, 10:47 PM
Not without a standalone computer, or the factory computer + the accompanying wiring harness.
Sent from my LG-H932 using Tapatalk
hemirunner426 is online now
post #3 of 12 (permalink) Old 04-11-2019, 10:49 PM Thread Starter
JLD
How about the 4x4 vs 2wd part
JLD is offline
post #4 of 12 (permalink) Old 04-12-2019, 07:23 AM
Moderator
9297oldram's Avatar
You would have to shorten your driveshaft to use that trans, I have a 47re in my Blazer with a standalone controller.
9297oldram is offline
post #5 of 12 (permalink) Old 04-12-2019, 08:33 AM Thread Starter
JLD
Where did you find the controller, also is the trans from a 2001 beefier than the stock 95 trans
JLD is offline
post #6 of 12 (permalink) Old 04-12-2019, 10:04 AM
Moderator
9297oldram's Avatar
Dodge Transmission | E-TransControl , They are basically the same trans only the re is electronically controlled. The 24v's put out more HP and TQ so i'm sure it would be good for your truck.
post #7 of 12 (permalink) Old 04-12-2019, 11:41 AM Thread Starter
JLD
How about cross member?
JLD is offline
post #8 of 12 (permalink) Old 04-12-2019, 12:07 PM
The Uppity 12v Guy
dauntless89's Avatar
Crossmembers are the same from 94-97 across all trucks (1500-3500). 98-02 crossmembers are still compatible but also accommodate the NV5600 without modifications.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is online now
post #9 of 12 (permalink) Old 04-13-2019, 09:43 AM Thread Starter
JLD
So it appears this tranny will bolt right in with a standalone and drive line modified, are there any other hidden surprises I might run into, I just want to have everything prepared.
JLD is offline
post #10 of 12 (permalink) Old 04-13-2019, 10:37 AM
Moderator
9297oldram's Avatar
Does the transfercase have the VSS in the tailshaft so your speedometer will work? Sometime around those years they went to the tone ring in the rear axle for the speedometer.
But you could always use a GPS speedometer like I did.
post #11 of 12 (permalink) Old 04-13-2019, 10:54 AM Thread Starter
JLD
My truck is 2wd, no t-case
JLD is offline
post #12 of 12 (permalink) Old 04-13-2019, 11:30 AM
Moderator
9297oldram's Avatar
I know that but the 47re you said was a 4x4 trans.
Similar Threads
47rh or 47re for 12 valve swap? Dart340w2 Cummins Conversions - Shop Talk - Tools - Fabrication 9 07-23-2016 02:11 AM
47RE or 47RH?? CONFUSED!!! Grapevine1 94-98 Powertrain 24 05-24-2016 09:59 PM
47rh or 47re which is right for me? Cumminpwr11 94-98 Powertrain 28 03-29-2016 12:20 PM
47RE transmission troubleshooting chart. country_hick 94-98 Powertrain 0 02-25-2013 12:30 PM
47re 47rh tc whitehick 94-98 Performance Parts Discussion 1 02-18-2011 01:26 AM
