Hydroboost swap help - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 04-10-2019, 01:28 PM Thread Starter
rcmac's Avatar
I am in the process of completing a hydroboost swap and undertaking some other repairs the required the IP removal. While the IP was getting repaired I thought it would be best to go ahead and install the vacuum pump and power steering pump assembly since there is more room with the IP removed. Upon installing the IP, I noticed that there isn't enough clearance for the return spring hanger to move past the new power steering pump. I have confirmed that the pump is correct. Any help is appreciated.
/var/folders/cq/2pyhj0y15d16bddv9__gb4rw0000gn/T/com.apple.iChat/Messages/Transfers/IMG_1311.jpeg
SB 3250 1 3/8", Arp625, 60lb springs,188/220,hd pushrods, 4gsk, bosch race 2 120hp sticks, #10, 191, ats 3 piece, r700's, 19*, arp rod bolts/main studs, ad165, o ring block, balanced pump, balanced bottom end
rcmac is offline
post #2 of 4 (permalink) Old 04-13-2019, 11:55 AM
Moderator
9297oldram's Avatar
Your link doesn't work so that we can see your picture.
9297oldram is offline
post #3 of 4 (permalink) Old 04-13-2019, 12:41 PM
The Uppity 12v Guy
dauntless89's Avatar
I've had to loosen or remove that bracket from the IP every time I've messed with my power steering pump.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #4 of 4 (permalink) Old 04-14-2019, 10:59 PM Thread Starter
rcmac's Avatar
Thanks for the responses. To clarify, it's the main spring retention bracket on the bottom side of the IP. I ended up grinding a notch in it to accommodate for the larger pump.
rcmac is offline
Similar Threads
RaceME with 2nd gen swap vb712 4th Gen Performance Parts Discussion 12 07-21-2014 10:32 AM
need MAF sensor port in intake tube for 2nd gen swap? best swap kit to buy less manif pipelinerREESE 07.5 - 09 3rd Gen 6.7L Performance Parts Discussion 1 04-22-2014 07:59 AM
NV4500 Swap Tutorial With Pictures Diesel_Addiction 94-98 Powertrain 24 12-01-2013 03:15 PM
Manual to Auto Swap questions luckyhat12 3rd Gen. Powertrain 12 09-11-2012 07:01 PM
d80 limited slip carrier swap possible? brianell 98.5-02 Powertrain 3 08-08-2012 02:16 PM
