12v Cummins exhaust smoke hot/cold idle - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-09-2019, 08:11 PM Thread Starter
12v with a p pump. 5x.012 power driven diesel injectors and his .055 delivery valves, timing was set to 18 degrees. Rechecked timing today and it looked like it slipped to 20.5 degrees. Is that normal for it to slip and add timing? I thought they pulled timing when they slipped?
I’m getting a white smoke out of the exhaust cold and hot idle. Soon as you accelerate and get into 1-5 psi of boost on a normal take off it does away. Fresh head gasket and studs. Doesn’t use coolant or oil. It runs really good but I’m wondering if someone can help me with the smoke issue? Brand new 364 turbo also.
5912valve is offline
post #2 of 7 (permalink) Old 04-09-2019, 08:32 PM
GAmes's Avatar
iTrader Score: 7 reviews
It is highly unlikely that it slipped higher unless the gear did just short of a full revolution. I suggest you check it again.
GAmes is online now
post #3 of 7 (permalink) Old 04-10-2019, 06:46 AM
Something strange going on with this. Any more information available?
Did you do the work?
When the delivery valves get done, it is a good time to bench the pump, was that done?
'98 Ram 3500 12v 4x4, triple disc/47RE, 3.54s, 275 70 17's, TT OFV, gauges, 16*, K27, 055, 5 x 0.011, AFC live, 3 pcs manifold, MBRP, AFE
'18 Promaster 1500 HT
RamCumminsRob is offline
post #4 of 7 (permalink) Old 04-10-2019, 09:45 AM Thread Starter
I did do the work. And I figured out when I rechecked the timing I didn’t apply for back lash like when I originally set the timing up according to power driven instructions.
I did not bench the pump. I left the pump on the truck and swapped the injectors/delivery valves at the same time. It ran very good after that and I didn’t notice any hazing. About 2 weeks later I bumped the timing from 12.5 to 18. It slipped the same day and started pouring white smoke out of the exhaust. Got it home thankfully and retimed it to 18 with a better method and a new washer and it’s been great ever since. Except the hazing at idle.
post #5 of 7 (permalink) Old 04-10-2019, 10:34 AM
GAmes's Avatar
That haze is wasted fuel, and that is what other than stock DVs are famous for. The first guy that I know of that pushed a 12 valve to 800hp many years ago tried different DVs and ended up using the stock ones in his 215 pump.
GAmes is online now
post #6 of 7 (permalink) Old 04-10-2019, 11:07 AM Thread Starter
I guess it’s worth the little bit of time swapping back to the stock dv’s. I’d rather lose power and it be more efficient and run clean. It draws attention with the haze by the unaware and someone thought it was broken cause of that lol.
Do we know where the 055 PDD DV’s Stand compared to the 131’s, 181’s, 191’s, and the laser cuts? Can’t seem to find any info on them
post #7 of 7 (permalink) Old 04-10-2019, 11:12 AM
GAmes's Avatar
I'm pretty sure that Dauntless89 wrote a post about them not too long ago.
GAmes is online now
Similar Threads
exhaust brake causing smoke show during engine warmup? underp2 3rd Gen. Powertrain 35 02-01-2016 06:57 PM
04.5 blow by & exhaust white smoke. Rough idle and oil everywhere. t.will 3rd Gen. Powertrain 23 11-05-2015 10:40 PM
idle with or without exhaust break overnight in cold weather? dnguillory 4th Gen Powertrain 13 03-02-2014 09:16 PM
Bad idle and smoke.... Code P0148 RSW 3rd Gen. Powertrain 0 04-23-2012 09:15 PM
Intermittant misses, Rough idle, Lopey High idle and black smoke Poops 3rd Gen. Powertrain 3 10-01-2011 12:24 AM
