Throttle getting stuck wide open - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 04-08-2019, 09:54 PM Thread Starter
hey i just bought a problematic 94 2500 12v automatic. first the fuel shutoff solenoid fell off the engine. and i found all of the AFC housing bolts stripped out. now the throttle is getting stuck wide open. i have inspected all to the linkage and cables and found what i believe is the transmission kick down cable getting hung up on the apps.
it looks like all the brackets are in the right spot and not bent. has anyone else had this issue???
is there a diagram for the shift linkage location and i assume there should be a return spring on the pump ??
thanks for the help
elascelles is offline
post #2 of 3 (permalink) Old 04-08-2019, 11:28 PM
Loud Pedal's Avatar
Merry Xmas
Free service download
https://redirect.viglink.com/?format...SXJMYlk%2Fedit
98-4x4 5spd
Loud Pedal is online now
post #3 of 3 (permalink) Old 04-09-2019, 10:07 AM
Moderator
9297oldram's Avatar
When I bought my 97 the trans kick down cable was frayed and the trans wasn't shifting right but never caused the throttle to hang up.
9297oldram is online now
Similar Threads
Cool and Spring from radiator cap under wide open throttle only Vanillagorilla40 3rd Gen. Powertrain 7 11-29-2017 10:35 AM
Quadzilla ADR 4k pedal stuck wide open. Jordank520 98.5-02 Performance Parts Discussion 8 01-11-2014 01:32 AM
Throttle stuck Wide open...Run away acceleration 2005 5.9L fishandride 3rd Gen. Powertrain 27 05-27-2013 03:04 PM
p7100 throttle lever stuck?? blakeape 94-98 Powertrain 5 12-03-2012 10:44 AM
2002 and newer Chrysler, Dodge Computer DTC Error Codes part 1 Reddevil1 3rd Gen. Powertrain 3 07-25-2012 06:14 PM
