47RH to RE OD housing - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 04-06-2019, 08:50 PM Thread Starter
12valvediesel's Avatar
Started gathering parts for auto swap about a year ago and...
picked up a 241dhd transfer case with driveshafts(regular cab like mine) for cheap off of a 2000 Dodge 2500 46re and was planning on finding a 47re to pair it with (both 23 spline)
Looked for 9 months and finally found a deal on a 47rh. Oh well, I can mess with driveshafts.
Did some searching/figuring and the 47rh needs a longer input shaft on the transfer case to seal/full engagement and obviously driveshaft length diffences as stated
I plan on doing a full manual valvebody so I don't think I will need the governor on the 47rh anyhow so my idea...
Will a 47re od housing and output shaft work on a 47rh?
How about 46re? Those are a dime a dozen at the salvage yard and supposedly the same as a 47re based on what I can find.
Just thinking it would save me the messing around swapping transfer case inputs, driveshafts, and possibly less likely to crack with a transfer case hanging off the back.
Any knowledgable input would be appreciated, Thanks
12valvediesel is online now
post #2 of 4 (permalink) Old 04-07-2019, 07:17 AM
Moderator
9297oldram's Avatar
The 46re is a Gasser trans and not strong enough, and the reason they are so cheap is because there was more gas then diesel trucks made.
The 47rh trans is a couple inches longer then the re, if doing a manual VB why not just use the rh.
9297oldram is online now
post #3 of 4 (permalink) Old 04-07-2019, 09:39 AM
alanack6795's Avatar
High performance parts are more readily available for the re.
alanack6795 is offline
post #4 of 4 (permalink) Old 04-07-2019, 10:05 AM Thread Starter
Thanks for the input. My plan was to put just the overdrive housing from an re on the rh. If it were as simple as finding a 47re I would have done that. Looked for almost a year and finally found a 47rh.
Similar Threads
48re overdrive housing options? cumminssladek15 3rd Gen. Powertrain 11 03-12-2018 12:55 AM
2nd gen Dodge Ram Hid Projector Retrofit DIY tutorial, with pics. 01dirtydzl 98.5-02 Non-Powertrain 60 04-14-2015 11:51 PM
47RH extension housing broke and need to swap mopar01 94-98 Powertrain 0 08-12-2011 11:03 PM
Exhuast Manifold leak? Anyone got ideas. Classy 3rd Gen. Powertrain 8 03-11-2011 08:37 PM
