Which head gasket? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 04-06-2019, 11:09 AM Thread Starter
Which head gasket?
Long story short got my head milled and was warped pretty bad they said they took off .014 and told me to get a thicker head gasket. They werent sure what sizes were out there so they couldnt tell me on the spot. I looked it up and i found cummins makes the standard thickness, .010 thicker and .020 thicker.
My question is which 1 should i go with? .010 thicker? Or .020?
Pchris is offline
post #2 of 6 (permalink) Old 04-06-2019, 03:34 PM
GAmes's Avatar
iTrader Score: 7 reviews
The thicker head gaskets are for engines that have had the deck shaved and take up the space of piston protrusion. If you only had a valve job done you should only need a stock thickness gasket.
GAmes is offline
post #3 of 6 (permalink) Old 04-06-2019, 04:01 PM Thread Starter
Oh really? Even with .014 taken off? And what about valves? Do i have to worry about valves hitting pistons?
Pchris is offline
post #4 of 6 (permalink) Old 04-06-2019, 05:15 PM
GAmes's Avatar
Yes really. If you had to worry about the valves hitting the pistons I would have told you. I'm assuming the machine shop knows how to do a valve job, however, since they advised you to get a thicker head gasket I have my doubts.
GAmes is offline
post #5 of 6 (permalink) Old 04-06-2019, 05:25 PM Thread Starter
Okay great thank alot man
Pchris is offline
post #6 of 6 (permalink) Old 04-07-2019, 01:08 PM
Destroked 450's Avatar
Measure how deep the valves are recessed into the head. Cummins recommends min .039 to max .060
Taking .014 off the heads surface shouldn't be enough to get it below min valve depth, if it did the valves need reworked.
As GAmes said different gasket thickness are for blocks that have been decked like mine.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
Similar Threads
$4,000 quote to replace head gasket, would like advice. jjgernaat 3rd Gen. Powertrain 26 02-09-2019 01:27 PM
Stumped on Coolant in Oil after Head Gasket Replacement riloedebuske 94-98 Powertrain 9 01-03-2019 10:39 AM
.010 head gasket question joelykool 94-98 Performance Parts Discussion 9 11-28-2014 07:35 AM
What Head gasket to use??? carolinarednek 94-98 Powertrain 6 03-04-2011 08:11 PM
