Is ATF2 ok for 96 5.9 auto tran. - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 04-04-2019, 11:36 PM Thread Starter
Decalman's Avatar
I always use ATF plus 4 tranny fluid.
My truck went in the shop for a couple of days the shop fixed a nice air leak in my fuel system got it running perfect , but due to a leak from a loose screw, my transmission was down several quarts and slipping.
The shop looked at my dipstick and it said ATF 2 on it so they thought that's what you put in.
My original dipstick broke a couple years ago and I had to buy another one.
Is ATF 2, okay to mix with my ATF 4???
It's seems to run real good
Decalman is offline
post #2 of 8 (permalink) Old 04-05-2019, 12:10 AM
myother4x4isaCJ7's Avatar
Iíd be curious where they got atf2 since it isnít manufactured anymore.
myother4x4isaCJ7 is offline
post #3 of 8 (permalink) Old 04-05-2019, 11:23 AM
Hey got your PM and tried to reply, not sure if your inbox is full or my phone is just being stupid but I donít think it will let me reply.
You should be just fine a dodge trans is really not picky with atf you can put really any kind in it. I would say if it drives just fine then donít worry about it. ATF+4 is the proper fluid to use but shouldnít have a trouble mixing with ATF2 or whatever they put in.
post #4 of 8 (permalink) Old 04-05-2019, 11:39 AM
alanack6795's Avatar
Atf +2 orDextron 3 is the correct fluid. Atf +4 shifts softer if that's what your looking for .
Atf 3/4 replaced Atf 2
alanack6795 is offline
post #5 of 8 (permalink) Old 04-05-2019, 11:50 AM
Thatís true, atf +2 was what was used when the trucks were made new. I believe +4 is thinner viscosity so that explains soft shifts.
Atf+2 has not been produced for a while I believe so still not sure what the shop put in maybe it was dex 3?
post #6 of 8 (permalink) Old 04-05-2019, 01:03 PM
Moderator
9297oldram's Avatar
Here is some reading https://www.allpar.com/mopar/transmissions/fluids.html
9297oldram is online now
post #7 of 8 (permalink) Old 04-07-2019, 01:31 AM Thread Starter
Decalman's Avatar
Thanks for the info
Decalman is offline
post #8 of 8 (permalink) Old 04-14-2019, 12:27 AM Thread Starter
Decalman's Avatar
Thanks. I appreciate your sharing this info
Decalman is offline
Similar Threads
Rattle, Tick or Knock sound... Seems to be coming from Bell Housing area on Auto Tran Jade67 3rd Gen. Powertrain 7 09-17-2017 10:36 PM
****Who has the fastest 6.7? Post 1/8th and 1/4 here**** THE STIG 07.5 - 09 3rd Gen 6.7L Performance Parts Discussion 806 10-11-2016 03:55 PM
4th gen auto to manual and vice versa swap Dodgeram082500 4th Gen Performance Parts Discussion 38 12-10-2015 05:42 PM
Lets talk stock auto tran temps! TXappraiser 2010-2012 General Discussion 21 06-27-2012 10:16 PM
Auto vs manual commtrd 3rd Gen. Powertrain 17 05-23-2011 08:41 AM
