Stripped out preboost screw - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 04-03-2019, 07:19 PM Thread Starter
Dallyquad12er's Avatar
Just yesterday installed new injectors and started tuning this evening after work on my way home.
Overtightened the nut on the preboost screw and stripped out the threads.
Besides a helicoil, does anybody have a suggestion on how to fix this? Will I need a whole new housing? If so, does anybody here have one for sale they wouldn't mind parting with?
Dallyquad12er is offline
post #2 of 6 (permalink) Old 04-03-2019, 07:22 PM Thread Starter
Thinking I'll actually just tap it and put a larger screw in.
And not overtighten it.
Would there be an issue with this?
post #3 of 6 (permalink) Old 04-03-2019, 10:14 PM
I've never done it on that exact bolt but I believe that is what I would do
1986 chevy crew cab 4x4, 160hp 12 valve, 5x14 inj., afc live, 4k gsk, rack plug, vulcan 1/2 fuel line with sump, tork tek ofv, he351cw, nv4500, 3.55 gears.
hussey is offline
post #4 of 6 (permalink) Old 04-03-2019, 11:13 PM
I'm pretty sure mine is stripped out as well. It is not able to work properly if it's stripped? I can't decide if I should fix it or if its ok to leave it stripped.
2001 Dodge 2500. Short bed, extended cab. 2wd.
1969 chevy c-10. 502 crate engine.
1969 chevy camaro. real z-28
dohyde34 is online now
post #5 of 6 (permalink) Old 04-03-2019, 11:45 PM
The Uppity 12v Guy
dauntless89's Avatar
I don't see how you'd use that adjustment if it's stripped.
You have two options. You can heli-coil it, or you can tap it out to the next size. If you stay metric, the next standard size is M8x1.25 which will offer a coarser adjustment than the original M6x1. You could tap it to 5/16-24 and maintain the same adjustment, if you're okay with mixing standard and metric threads on a component.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #6 of 6 (permalink) Old 04-10-2019, 03:33 PM Thread Starter
helicoiled it. Thanks dauntless.
Similar Threads
Electronic smoke screw adjuster idea DieselBrad 94-98 Performance Parts Discussion 17 03-30-2015 02:46 PM
lost my idle screw..HELP Jefferson1997 94-98 Powertrain 1 03-12-2015 01:50 PM
Stripped out smoke screw nut!!!! Help! jmerriman17 89-93 Powertrain 4 01-12-2014 12:39 PM
Adjusting 1-2 band, trans shop recommendation? Mxhead 3rd Gen. Powertrain 13 11-15-2012 01:28 PM
Stripped fuel bleeder screw? jdb1911 94-98 Powertrain 1 09-09-2011 03:29 AM
