Tach jumping and Overdrive not working - Dodge Cummins Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 03-30-2019, 10:24 PM Thread Starter
zeke1's Avatar
Hello all, I have a 97 2500 2wd 12v. The tach is jumping around and the trans wont shift into overdrive, the Gen light stays on. Ive searched on here everything I've found says if its crank speed sensor on harmonic balancer is bad the the alternator and a/c wont work either but mine work fine. The transmission was completely rebuilt new torque converter new valve body according to trans shop someone had been in trans painted the torture converter and it had peeled off going into everything and supposedly the valve body was trashed. When I picked up it today still no overdrive and tach jumping. (After they were gone of course.) I am wondering could the TPS cause these 2 issues or am I wrong. No flash codes and when I hook scanner up no codes. Any help would greatly be appreciated.
zeke1 is offline
post #2 of 13 (permalink) Old 03-31-2019, 01:27 PM
gmanss's Avatar
Definitely sounds like the ESS. My tach would bounce around intermitently because one of the wires would periodically short out on the block where it had rubbed through due to vibration. I never lost AC and didn't notice the charging issue at first either but it would play havoc with the transmission.
gmanss is offline
post #3 of 13 (permalink) Old 03-31-2019, 01:42 PM Thread Starter
zeke1's Avatar
I found 2 of the 3 wires going to the low side of injection pump rubbed raw no insulation this morning, it plugs into the throttle plate down on the side, going to repair those and cross fingers. With a feeler gauge the ESS gap is .50 I believe I read thats about stock?
<~~ There are very few problems that cannot be solved with the proper application of high explosives ~~>
zeke1 is offline
post #4 of 13 (permalink) Old 03-31-2019, 11:30 PM
Computer Controlled ground for Overdrive
Many people make this mistake when overdrive goes out... The ground for Overdrive is controlled by the computer. Quick fix... check the ground off the computer or replace the computer.
DieselMech1981 is offline
post #5 of 13 (permalink) Old 03-31-2019, 11:31 PM
Tach will more than likely be the tach cable
post #6 of 13 (permalink) Old 03-31-2019, 11:51 PM Thread Starter
zeke1's Avatar
I repair wires overdrive started working and tach stopped jumping until I retaped the wires then back to jumping and no overdrive
zeke1 is offline
post #7 of 13 (permalink) Old 04-01-2019, 10:17 PM
GAmes's Avatar
iTrader Score: 7 reviews
Tach cable?? Have a part number for that?
Loud Pedal likes this.
GAmes is online now
post #8 of 13 (permalink) Old 04-01-2019, 10:25 PM
Loud Pedal's Avatar
or a picture of one in place
98-4x4 5spd
Loud Pedal is online now
post #9 of 13 (permalink) Old 04-01-2019, 10:42 PM Thread Starter
zeke1's Avatar
Yes picture/part number
zeke1 is offline
post #10 of 13 (permalink) Old 04-09-2019, 07:07 PM Thread Starter
zeke1's Avatar
Ok so today after work I installed new VSS, truck shifts in and out of overdrive, tach still jumps a little until I turn A/C on then it doesn't jump but still no overdrive and no charging any help would be greatly appreciated
zeke1 is offline
post #11 of 13 (permalink) Old 04-09-2019, 07:20 PM
GAmes's Avatar
All of those wires are depicted in the wire diagrams that are in the factory service manual. Have you done continuity checks and short to ground checks on them?
GAmes is online now
post #12 of 13 (permalink) Old 04-09-2019, 07:44 PM Thread Starter
zeke1's Avatar
No I haven't, I ordered a factory service manual and I'm waiting on it to get here. I pulled the truck by vin on mitchell1 at work but NONE of wires matced. So I'm awaiting my service manual. After reading other threads, I'm going to get a can of electric parts cleaner from work and go through all connections with that. Very aggravating
zeke1 is offline
Similar Threads
Auto Trans In and out of overdrive problem kibbleking 98.5-02 Powertrain 16 01-14-2016 08:06 PM
Speedo jumping shifting problems - have run out of options! Please help! MAbendschoen 911 Urgent Situations 15 08-15-2015 07:09 PM
06 Trans Question (overdrive in and out) steveothatguy 3rd Gen. Powertrain 3 10-01-2012 11:42 AM
tach jumping all over the place cummin&smokin 94-98 Non-Powertrain 3 08-29-2012 01:17 PM
losing overdrive chrisdeal 94-98 Powertrain 1 08-08-2011 09:11 PM
