Trans overheating, OD and AC go off - Page 3 - Dodge Cummins Diesel Forum
 2Likes
post #25 of 32 (permalink) Old 04-06-2019, 01:00 AM Thread Starter
Cheeze's Avatar
Originally Posted by Gator1 View Post
That heat exchanger needs to be on. If you disconnect the the hot water side it will cool the trans better. I would never remove completely unless I was adding another remote cooler. It sounds to me like your trans guy is trying to kill your trans so you'll come back for another. Also 200 deg is way too hot. it shouldn't go over 170 to 180 max!
How can it cool better with no water going through it?
96 12 valve club cab lwb 2500 2wd 250k 3.55 gears, 265/75-r16, OFV at 30, no plate, AFC full fwd, HX35 at 35 psi boost, Timing~16.5, 5x11s, 2790 BHAF, Banks hi-flo muffler, 3.5" exhaust, Deleted prefilter & heater, mildly built 47re, billet single TC. KDPF
Cheeze is offline
post #26 of 32 (permalink) Old 04-06-2019, 01:05 AM
Gator1's Avatar
because the water going through it is 200 deg, the water is actually heating it up! and the air going through it is much less.
03 QCLB- 19 to 25 mpg with electric parts, and engine mods....
Gator1 is offline
post #27 of 32 (permalink) Old 04-06-2019, 02:58 AM Thread Starter
Cheeze's Avatar
Air doesn't go through it.
Cheeze is offline
post #28 of 32 (permalink) Old 04-06-2019, 02:42 PM
Gator1's Avatar
It does if you disconnect the water hoses and allow it to. More of a heat sink, but the general consensus is it's worth 5 to 10* drop in ATF temps.
Gator1 is offline
post #29 of 32 (permalink) Old 04-06-2019, 03:37 PM Thread Starter
Cheeze's Avatar
The heat exchanger doesn't cool better with the water disconnected then. So 270* without it, 170* with it, or 260-265* with it and no water connected? The hot water cools it.
Cheeze is offline
post #30 of 32 (permalink) Old 04-06-2019, 04:59 PM
Gator1's Avatar
Ya, I think they had in mind to help warm up the trans in colder climates. I don't buy the notion that 220* water cools the trans fluid, because that's too hot. Nobody in their right mind wants trans temps over 200 deg... I like to see my trans temps around 100 to 120* and 170 max, at which point the fan on my aux cooler will kick in, or I can hit the over ride switch to keep it in check.
Gator1 is offline
post #31 of 32 (permalink) Old 04-06-2019, 09:05 PM Thread Starter
Cheeze's Avatar
I just went through this here in this thread and proved it cools it. I went from 220-280 temps not even pulling a load down to 170 while pulling a camper. The only difference was having the heat exchanger connected. My water temps never reach 220. Usually 190 or so.
Cheeze is offline
post #32 of 32 (permalink) Old 04-06-2019, 10:45 PM
Gator1's Avatar
Well that's true in your situation.... if my trans temp was 270 then 200 deg water would help to cool it. I'm glad that it helps in your situation. But like I said I like my temps closer to 100 not 200 and i do not use the factory radiator mounted trans cooler either, I have found that the heat that comes off it causes high radiator temps...
Gator1 is offline
Similar Threads
Trans problems while tuned. Back to stock no problems. Was a "re learn" needed? Crodgers14 4th Gen Powertrain 12 01-23-2014 11:21 PM
At witts end with this automatic NEED ADVICE TRANS GURUS! pepsi71ocean 98.5-02 Powertrain 18 03-04-2013 06:30 AM
trans wont go into overdrive?!?! ifyoucantdodgeitramit 94-98 Powertrain 11 08-29-2012 09:37 PM
Urgent. Fan won't engage Engine and trans are overheating 600crpower 3rd Gen. Powertrain 12 07-07-2012 06:37 PM
