Injection Pump Rebuild - Page 3 - Dodge Cummins Diesel Forum
 1Likes
post #25 of 26 (permalink) Old 04-09-2019, 10:23 AM
Nascar's Avatar
Originally Posted by EXSwap View Post
The delivery valves didn't look like anything I'd seen here, but I figured out later that that's because I didn't take them all the way apart. I'll at least pull one apart so I can more positively identify them. They had "009" on them that I could see.
Your pump is an industrial pump, not an passenger style pump, that's why your DV's look different.....not because you didn't pull it apart all the way.
Other than the pump being a dirty mess ( yes, rebuild time ) doesn't mean it can't be used. Different DV's & slightly heavier gov weights, no problem as long as your not looking to go big power or high rpm, you can run it.
98 12v w/G56, 700ccs, My stg5 twins, cam, taper cut DV's, 90hp injs, high volume/pressure lift pump, stg3 head
DieselTuff
Nascar is offline
post #26 of 26 (permalink) Old 04-09-2019, 02:33 PM Thread Starter
EXSwap's Avatar
That was my original intention (to run the pump), put in a 3K GSK and a #10 plate. Other than that, I wasn't planning on anything else as far as performance mods. I may fiddle with it a bit more before calling it. Potentially I could clean it up and run it but I'm not sure it's worth the stretch at this point given the $$ I have in the overall project.
EXSwap is offline
Similar Threads
Injection pump timing BullyBreed 89-93 Powertrain 13 03-06-2017 01:32 PM
wont start 0251 code gearhead1 98.5-02 Powertrain 17 09-18-2013 09:08 AM
Injectors Ticking/No Start 71fordcrewcab 3rd Gen. Powertrain 14 04-15-2013 11:41 AM
Ram will not accept throttle? Pig Iron 98.5-02 Powertrain 5 10-29-2011 11:50 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
