Secondary Idle Adjustment? - Dodge Cummins Diesel Forum
 3Likes
post #1 of 30 (permalink) Old 03-04-2019, 05:10 PM Thread Starter
SFGiants's Avatar
I've read up on the posts about adjusting the motor's idle using the throttle linkage rod, but what else can be done beyond this?
I've maxed out the length of my linkage on both ends (threaded rod almost unscrewed from the female ends), but my idle is still on the low side, right about at 500 in Drive w/ A/C on. Want to get it up to about 650 here as it's hard starting at the current level.
When I installed my new p-pump, I recall there was a plate on the side of it towards the back of the pump where the linkage connects. Can this be adjusted too? It looked like it was possible to change the angle of it, thus taking up some of the slack in the linkage. Now that's it's installed in the truck facing downwards, it's hard to see much.
What's even more bizarre, my linkage rod was capable of conventional idle adjustments right after I installed my new pump. The truck at first idled too high, so I backed it off quite a bit. Now I need to increase it, but the linkage is all maxed out. Any ideas what caused this?
'97 2500 Laramie 4x4, 60-lb Valve Springs, 4K GSK, PDD Stage 3 P-Pump, MBRP 5" Exhaust, PDD AFC Live, Built 47RE, Thuren 2" Coils, Bilstein 5100, Synergy track bar, RedHead Steering Gear
SFGiants is offline
post #2 of 30 (permalink) Old 03-04-2019, 06:13 PM
Stox225's Avatar
You shouldn’t adjust your linkage. If you follow it all the way to the rear of the pump, it all rests on a cap screw. There’s a jam nut on the underside you loosen and then spin the cap screw up to increase throttle. 10mm I believe.
SFGiants likes this.
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; 98-99HD Steering; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug;
; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF
Stox225 is offline
post #3 of 30 (permalink) Old 03-04-2019, 06:48 PM
Ooofff you should of left that alone. That rod is not meant to adjust idle. It is used to make sure the TPS, TV, and cruise control are all in proper alignment. There is only +-1mm adjustment allowed there and that is used for TPS adjustment.
The proper way to adjust idle is at the low idle stop on the pump.
hemirunner426 is offline
post #4 of 30 (permalink) Old 03-04-2019, 07:44 PM Thread Starter
SFGiants's Avatar
Gosh darnit.
Ok, thanks guys. I'll give that a try. Hopefully the linkage isn't too messed up. I'll try to reset it towards somewhere in the middle for now.
98whitelightnin likes this.
SFGiants is offline
post #5 of 30 (permalink) Old 03-04-2019, 09:26 PM
GAmes's Avatar
iTrader Score: 7 reviews
I suggest you open the factory service manual and adjust both the linkage rod and the idle by the book. Not much point in having a correct tool if you don't use it.
GAmes is offline
post #6 of 30 (permalink) Old 03-04-2019, 10:51 PM Thread Starter
SFGiants's Avatar
Do you guys back off the locknut a ways down the screw, and then turn the screw by hand from its tip underneath? I'm having a heck of a time getting two 10mm wrenches down there.
SFGiants is offline
post #7 of 30 (permalink) Old 03-04-2019, 10:54 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Yes, get it about where you want it and then tighten the lock nut. The idle will adjust up or down (Cant remember) a little when you tighten it down.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
SFGiants (03-04-2019)
post #8 of 30 (permalink) Old 03-05-2019, 12:36 AM
ekvhekvh's Avatar
Hope you’re taking GAmes advice on the manual and setting your linkage by the book. You can take the tranny out in short order with the wrong settings.
96 Ram 2500 4x4 automatic. Engine number: ??? Missing.
ekvhekvh is offline
post #9 of 30 (permalink) Old 03-05-2019, 12:59 AM Thread Starter
SFGiants's Avatar
Yes, I'm going to address this tomorrow. And goodness, I did not realize it was that critical. I appreciate the warning.
SFGiants is offline
post #10 of 30 (permalink) Old 03-06-2019, 06:21 PM
GAmes's Avatar
It isn't in the easiest place to get to, but using a 10mm wrench from the top is how I do it. Having a helper to hold the throttle full forward would make it a bit easier. The bolt goes up to increase idle. A little bit of adjustment goes a long way.
GAmes is offline
post #11 of 30 (permalink) Old 03-06-2019, 06:28 PM
The Uppity 12v Guy
dauntless89's Avatar
Part of the finickiness is the tendency of the throttle arm to wear a crater into the head of the bolt. I took mine out and recrowned it in the lathe, very easy to get it dialed in now.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #12 of 30 (permalink) Old 03-06-2019, 08:07 PM Thread Starter
SFGiants's Avatar
Thank you for the details, sir.
I was fighting like hell trying to get both hands down there AND be able to see the low idle screw at the same time. As soon as I gave up on seeing what I was doing and went by feel, it actually wasn't too bad. A 10mm ratcheting wrench on the bottom to loosen/tighten the nut relatively easily and a stubby on the bolt did the trick.
Regarding the throttle linkage, I was within an 1/8" of the 5 inch spec and figured it was close enough to drive to the shop today for my valve spring install, however, I'm going to go back in there tonight and get it perfect. Ended up adjusting the idle too high yesterday too, I did it with a cold motor and didn't compensate well for how it increases once warm.
SFGiants is offline
Similar Threads
quadzilla tune downloads jigabop 98.5-02 Performance Parts Discussion 109 08-31-2015 03:09 PM
98 12v idle adjustment. steven.bunker 94-98 Powertrain 1 02-01-2015 03:51 PM
rough idle down and sounds like a lope at idle spyder982 2003/2004 General Discussion 13 01-15-2014 12:35 PM
Idling Drzr 2013-2018 General Discussion 92 12-24-2013 12:54 PM
Idle adjustment w/ no tach Lowshooter 89-93 Powertrain 7 10-17-2013 10:10 PM
