I think I've lost it. 12/24 Volt Conversion. - Page 2 - Dodge Cummins Diesel Forum
 5Likes
post #13 of 21 (permalink) Old 03-07-2019, 10:12 PM Thread Starter
f5c140al's Avatar
Oh, It's worth the effort. I have some 24V accessories I'd like to run. Besides, once I have the new alternator fitted to the engine, that'll leave space where the old one was for a second AC compressor to use for on board air.
I'll hit the local cummins dealer and see if they can look it up for me.
The hardest part of this will be fitting the enormous 200 amp alternator to the engine. LOL
1997 Ram 2500, ECLB, 12V, 4X4 Auto
4" TBE, Built 47RE, stock converter (for now).
99 Ram 2500, QCLB, 24V, 4X4 Auto, Donor truck
f5c140al is offline
post #14 of 21 (permalink) Old 03-07-2019, 11:25 PM
Electrojake's Avatar
FWIW...
A company called Phillips & Temro Industries manufacturers the grid heaters that are used in the Cummins engine.
They can be had in 12 or 24 volt versions.
Good luck & happy wrenching,
-Ej-
2016 Longhorn 3500 4x4 short-bed in Pearl White.
Cummins-AISIN, CrewCab, SRW, Ride-Rite remote rear air suspension, Edge CTS2, plus the typical after-market bolt-on crap.
*Hauling a 2017 Northstar Arrow-U.
Electrojake is online now
post #15 of 21 (permalink) Old 03-08-2019, 12:29 AM
Destroked 450's Avatar
24 volt parts are rarer and usually higher priced, one reason I'm going to remove all of the 24v items from my 5 ton 6x6 and convert it to 12volt.
Years ago Kenworth used a polarity switch setup for 24 volt start and 12v operate.
Starter was 24v, lights and accessories were 12v, not sure about the alternator.
Sounds like a lot of work and messing up a good truck just to run a few 24v accessories.
Are you going to swap out the heater blower motor, windshield wiper motor, all of the lights and relays as well, don't forget about the 12v dash and sending units.
dd453ford likes this.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #16 of 21 (permalink) Old 03-08-2019, 09:45 AM
M37
M37's Avatar
Think of the resale value or lack of it with a 24v hybird.
M37 is offline
post #17 of 21 (permalink) Old 03-08-2019, 11:13 AM
Jimmy N.'s Avatar
I have converted 6 to 12 Volts, and 24 to 12, but would never consider 12 to 24.
Having several 24 Volt vehicles, I know what a pain it can be to run regular accessories and attachments off their systems without punishing one of the two batteries.
Of course, the ultimate cluster fs are my M1008 and M1031. One alternator for each battery, and everything except the starter is 12 Volt.
Yes, I understand the reasoning (standardized 24 Volt communication systems) and have to admire the thinking that went into making it work.
But keeping it working, and keeping the battery that supplies the 12 Volt happy, isn't as simple as it could be.
Still, if forced to create a partial 24 Volt system, that's what I would reluctantly copy.
'14 1500 V6, '17 3500 C&C, plus a '17 2500 in the household.
Jimmy N. is offline
post #18 of 21 (permalink) Old 04-05-2019, 10:14 AM Thread Starter
f5c140al's Avatar
Originally Posted by M37 View Post
Think of the resale value or lack of it with a 24v hybrid.
I'm not concerned with resale. I'm driving this truck into the ground in another million miles or so.
I hear you. I was considering that system, until I remembered the HMMWV system with a dual voltage alternator That way, all 24V runs off both batteries, and 12V punishes the the other, but the single alternator charges the batteries.
f5c140al is offline
post #19 of 21 (permalink) Old 04-05-2019, 10:59 AM
Jimmy N.'s Avatar
That sounds like a simpler setup. One I've never tinkered with.
Speaking of resale value. It might have dropped a bit when I cut 31 inches out of the frame to make my M1008 a more maneuverable tow vehicle/yard goat.
That didn't bother me one bit, as I made my vehicle more usable for me. I don't quite understand your desire to have a 12/24 Volt system, you probably wouldn't want a really short pickup without a bed. We're even. Life is good.
Jimmy N. is offline
post #20 of 21 (permalink) Old 04-05-2019, 11:42 AM
alanack6795's Avatar
I don't know I drove a brand new f350 and it was the biggest piece of crap I've ever seen.
I don't think I'm qualified to change a fuse in that truck.
Id rather spend 20 grand on an old crap box and make it the way I want.
alanack6795 is offline
post #21 of 21 (permalink) Old 04-10-2019, 08:07 PM
1070's Avatar
some of our construction stuff has a 24v system with a 24v-12v step down box to run the cab. I don't know how many amps those things can set up to run but that might be a easy way to make your system work.
94 5sp 4x4 4x13x155 2x4 to 4x4 converson.ford dana 60 lockout hubconv. 91.5 gas to 6bt conv. 2x4 to 4x4 conv.5x12x155 16deg timming fass 95 nv4500 conv p pump conv. 05 fass95 d60 lockout hub conv ats conv BD trans controller
1070 is offline
Similar Threads
4bt conversion, looking at 1st Gen 24 volt system... questions RCB Electrical & Wiring 1 03-09-2013 12:42 AM
Volt gauge drop to 0 o2rustyw02 98.5-02 Non-Powertrain 1 11-07-2011 11:36 AM
