1997 12v wastegate line diagram - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-15-2019, 03:45 PM Thread Starter
My trucks missing the line on the intake horn side by the valve covers. My truck leaks oil like crazy. I'm chasing oil leaks starting with the most obvious. Trying to get the waste gate back to stock from previous owner.
1997 12 valve
5 speed
132,000 miles
Cmac1990 is offline
post #2 of 7 (permalink) Old 02-15-2019, 07:02 PM
9297oldram's Avatar
All you need to do is run a boost line from the intake manifold. The factory is from the compressor housing to the controller.
9297oldram is offline
post #3 of 7 (permalink) Old 02-15-2019, 08:02 PM Thread Starter
Is there any pics available. I know just enough to get myself in trouble. The truck has leaked oil since I've had it. And I've been reading about the crankcase pressures. I know this isn't a complete fix, but I'm hoping itll slow it down.
Cmac1990 is offline
post #4 of 7 (permalink) Old 02-15-2019, 08:14 PM
Where is it leaking oil from?
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #5 of 7 (permalink) Old 02-15-2019, 09:02 PM
9297oldram's Avatar
Old truck equals dried out gaskets, valve cover, tappet cover 2 most common to leak.
post #6 of 7 (permalink) Old 02-15-2019, 09:02 PM Thread Starter
It's hard to pin point. I bought the truck for work. Took it to my mechanic to go over and make sure it didn't need rebuilt. He said the motor has very little blow by but some of the seals were bad. I haven't had a chance to clean the undercarriage yet. In the process of putting the starter back on. But I know the extra pressure isnt helping the oil loss. I'm thinking about getting patched up as best I can. Then putting it up for sell if I can get the right price
Cmac1990 is offline
post #7 of 7 (permalink) Old 02-15-2019, 09:06 PM Thread Starter
Tappet cover was replaced before I bought it. But yes I believe it set for some time. It runs great just have to keep a jug of oil handy. Got quoted 3 grand to replace all seals and throw a new clutch on just while it was apart. But if I go that route I'll just keep it for a toy
Cmac1990 is offline
Similar Threads
HE351CW question - wastegate actuator nosympathy 3rd Gen. Powertrain 2 09-07-2017 03:32 PM
LEak FUEL RAIL someWhere??HELP BLUEcummin 3rd Gen. Powertrain 8 10-29-2015 03:57 AM
S.U.R.&R. Brake Line Rezeppa 89-93 Non-Powertrain 9 01-15-2014 08:35 AM
Vacuum line diagram triflex 98.5-02 Performance Parts Discussion 2 10-15-2013 01:00 PM
Fuel Return Line diagram Daboocru 98.5-02 Powertrain 2 06-06-2011 06:13 PM
