HX35's... How quickly do you build 5lbs boost? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 18 (permalink) Old 02-13-2019, 08:40 PM
Originally Posted by 98whitelightnin View Post
Sac nozzles are usually hazy at idle. Pull one of them out and find someone that can give you an idea what your running.
So do 155* spray angles.
Sent from my LG-H932 using Tapatalk
hemirunner426 is online now
post #14 of 18 (permalink) Old 04-10-2019, 03:41 PM Thread Starter
Dallyquad12er's Avatar
Turns out I had 4x.011 injectors with the wrong spray pattern. Swapped in 5x.012 SAC Diesel Auto Power injectors and she's running alot better. Still not building boost properly. I'll be looking into boost leaks when the weather clears up and am looking for a larger turbo in the meantime. I know for a fact my turbo needs replaced asap.
Thank you all for your input.
Anyone have any suggestions on what would be a good match for the injectors I installed? I'm strongly considering an HE351CW. But if there's something that bolts right in I'm all ears.
Dallyquad12er is offline
post #15 of 18 (permalink) Old 04-10-2019, 03:51 PM Thread Starter
*spray angle
The ones I installed are 145
The 4x.011 were 155
post #16 of 18 (permalink) Old 04-10-2019, 04:08 PM Thread Starter
4x.014 155.... not 4x.011 155...
post #17 of 18 (permalink) Old 04-11-2019, 07:41 AM
blackDOHC's Avatar
I'm going the he351cw route soon as well, I snagged mine for $150. Just need to pick up a few odds and ends now.
There are quite a few options for actual drop in replacement turbos now days though. I'm on the fence now whether I should sell my 351 now that its all rebuilt and grab a drop in aftermarket turbo or just run it.
1997 ECLB - 5" Diamond Eye straight pipe - ISSpro Trans temp/EGT/Boost - AFC Live - boost elbow - 191s - Built trans - BHAF - ARP 425s
blackDOHC is offline
post #18 of 18 (permalink) Old 04-11-2019, 09:17 PM
Cheeze's Avatar
Mine hits 5 psi like one second after pressing the accelerator and quickly hits 18 or so on normal acceleration. Might hit 30-35 with pedal to the floor if I'm pulling or going uphill. I'm passing 1300 rpm or so when the boost gauge zips past the 5psi mark. I get a puff of haze unless I'm just putting around gently. I'm not one to putt around though. I need to put a larger exhaust on, that will help I think. I've been considering the K27 turbo but my Holset is still in very good condition and I'm trying to restrain myself lol. I think I'm on the ragged edge of what the HX35 can handle right now though.
96 12 valve club cab lwb 2500 2wd 250k 3.55 gears, 265/75-r16, OFV at 30, no plate, AFC full fwd, HX35 at 35 psi boost, Timing~16.5, 5x11s, 2790 BHAF, Banks hi-flo muffler, 3.5" exhaust, Deleted prefilter & heater, mildly built 47re, billet single TC. KDPF
Cheeze is offline
Similar Threads
cant build boost staging bangbang92 3rd Gen. Performance Parts Discussion 19 06-16-2015 04:09 AM
how to build boost on take off? wncmatthew 98.5-02 Non-Powertrain 17 07-05-2014 05:07 PM
Truck acted like de fueled now refuses to build boost EXCELerate23 3rd Gen. Performance Parts Discussion 9 06-07-2014 08:59 PM
how do i build boost? hdmatt 3rd Gen. Non-Powertrain 6 02-13-2011 09:58 PM
