Parts truck questions - Page 2 - Dodge Cummins Diesel Forum
 1Likes
post #13 of 16 (permalink) Old 02-14-2019, 04:36 PM Thread Starter
andrewp's Avatar
I was thinking that as well. I will probably use it for the time being because I have it and invest in something different a little later
andrewp is offline
post #14 of 16 (permalink) Old 02-14-2019, 07:59 PM
Stox225's Avatar
I second the turbo sell. And thereís no need for 5x.014 injectors. Especially if you go smaller turbo. My 5x.012 will support 550 HP
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; 98-99HD Steering; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug;
; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF
Stox225 is offline
post #15 of 16 (permalink) Old 02-16-2019, 02:24 PM
Destroked 450's Avatar
Sell the turbo and run you stock unit until you decide to upgrade to one that works best for your app.
Trade the 5x.014's for something in the 5x.010-5x.012 range.
If your looking to sell the 98 engine with a pump swap the 215 pump onto your engine and sell the 160 with the engine, otherwise hang on to the 215 for later use and sell the engine without a pump.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #16 of 16 (permalink) Old 02-16-2019, 08:44 PM
You don't happen to wanna sell that engine harness cheap do you?
my 96/01 swap truck I've cannibalized both "spare" harnesses to make an adapter between the 96 engine harness so it is unmolested, and the 01 cab harness is mostly unmolested.
Probably not worth my time changing all that wiring at this point considering it runs and all the lights and stuff I need to work works, but figured I'd ask just in case lol
Red Truck: 97 2500 4x4 ECLB 250k-ish, mostly stock.
Purple Truck: 01 1500 4x4 ECSB 12v Conversion, has all the 1996 3/4 ton stuff besides the body at this point.
JarodTLG is offline
Similar Threads
More stupid parts swap interchange questions. Pcm related. Killjoy 98.5-02 Non-Powertrain 3 05-30-2018 03:14 PM
My 3500 cummins parts to a 1500 questions Klongstreath 94-98 Powertrain 15 08-26-2015 09:32 PM
Performance parts questions for 2011 BR-549 4th Gen Performance Parts Discussion 1 01-01-2015 01:28 AM
A few parts questions for a Cummins nOOb McDowell 2010-2012 General Discussion 36 10-03-2014 12:50 PM
front end parts? rebuild blackcoal 98.5-02 Non-Powertrain 16 03-13-2011 05:42 PM
