OD housing cracked/exploded 100 miles after 47RH rebuild - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 02-07-2019, 04:12 PM Thread Starter
jhumphrey90's Avatar
I recently had my transmission rebuilt by a local shop in memphis (coleman taylor transmission). I have only driven the truck to work since the rebuild (4 weeks ago).
Last thursday on the way to work i was cruising on the interstate about 70MPH. I felt a light vibration and before i could take the cruise control off i heard a loud pop/bang of metalic noise (difficult to describe) followed by an intense vibration. Upon inspection after pulling over the overdrive housing had a crack from top top bottom where it mates to the main transmission case.
The shop has not called me back yet with a prognosis, but i briefly talked to the shop manager and he said something along the lines of "yeah this was probably a bad U-joint or motor mount". I am now worried by the tone in his voice that it won't be covered under warranty (2 year 24k miles).
1994 - Single cab - 3.55 gears - Stock 12Valve
270k miles
I will update the thread once the shop calls me back.
EDIT* it's difficult to see the crack, upload quality reduced on upload. It puked every ounce of fluid out once i pulled over.
Name:	damagged 47 RH.jpg
1994, 12v, single cab, auto, stock
jhumphrey90 is offline
post #2 of 12 (permalink) Old 02-07-2019, 04:20 PM
A damaged u-joint, driveshaft, or other component is a likely suspect.
Although I feel the shop should of inspected those components... Many do not.
Did you feel any vibration beforehand?
Edit: NM I see the front driveshaft. A transfer case issue could be a culprit too.
Sent from my LG-H932 using Tapatalk
hemirunner426 is offline
post #3 of 12 (permalink) Old 02-07-2019, 04:24 PM Thread Starter
Sorry i left that out. Indeed it is 4x4.
I had them service the transfer case and rear end as well when they did the rebuild. Additionally i told the guy to replace anything that looked "remotely" worn out because i planned on taking the truck cross country soon.
As you mentioned they should have inspected said parts, especially the U-joints since he would have had to put his hands on them.
post #4 of 12 (permalink) Old 02-08-2019, 12:04 AM
Yeah that's a tough one. Without going through the motions to figure out what happened it's anyone's guess.
Did you feel any vibration at any speed after the rebuild?
post #5 of 12 (permalink) Old 02-08-2019, 12:09 AM Thread Starter
I didnt notice any hint of vibration or irregularity after the rebuild. Drove great and didn't seem to function out of the ordinary.
Hopefully I will hear something tomorrow.
post #6 of 12 (permalink) Old 02-08-2019, 11:16 AM
Good luck.
Hopefully it works out in your favor.
post #7 of 12 (permalink) Old 02-10-2019, 04:21 PM
Cheatham's Avatar
sounds like a way for them to avoid a rebuild on thier dime. many cars and trucks will go down the road for a while with very bad u joints along with bad vibration and you dont hear of them wiping out a transmission unless you were on the throttle and hauling a$$ then thats good reason to tear one up
07 6.7 QCSB 2500 deleted. Smarty jr, straight piped sold. 2001 SRW QCLB sold. currently have 94 rc 3500. auto/trans, #5 plate, 4k gov. spring, gauges. straight piped. adj.o/f valve. Timing @ 17.5 new 5x12s, 024 D.V. AFC Live, Plate removed.
Cheatham is offline
post #8 of 12 (permalink) Old 02-10-2019, 04:34 PM
The Uppity 12v Guy
dauntless89's Avatar
Extremely unlikely an out-of-balance shaft or bad u-joint would cause that level of carnage. If it did, you would have been feeling all sorts of vibration. I suppose anything is possible but u-joints aren't really one of those things that are fine and then fail out of the blue.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
post #9 of 12 (permalink) Old 02-10-2019, 09:55 PM
Agreed. You'd know off the bat if that was a problem
post #10 of 12 (permalink) Old 02-11-2019, 12:18 AM
ekvhekvh's Avatar
I had a 68 Chrysler that wasn’t making any noise to indicate a bad ujoint. Late to a dentist appointment, a foolish young man decided to push the envelope a little and the ujoint let go at 115 mph. The yoke was thrashing around hitting the tunnel like a ten pound hammer. Tailshaft of transmission was all torn up. Foolish, but lucky young man he was.
96 Ram 2500 4x4 automatic. Engine number: ??? Missing.
ekvhekvh is offline
post #11 of 12 (permalink) Old 02-12-2019, 02:53 PM
Cheatham's Avatar
Also the shop could've swapped the overdrive unit from an re from a v8, they will interchange and it's a cheap way to do a rebuild, But there is a big difference in the internal of a v10 and diesel overdrive unit. Unless you check for yourself you may never know.
Cheatham is offline
post #12 of 12 (permalink) Old 02-12-2019, 05:15 PM
blackDOHC's Avatar
I never knew this until I was rebuilding the Jasper trans that came with my truck. Different clutch counts and a different backing plate if I remember correctly.
1997 ECLB - 5" Diamond Eye straight pipe - ISSpro Trans temp/EGT/Boost - AFC Live - boost elbow - 191s - Built trans - BHAF - ARP 425s - PSC SG852 - 315/75/16
blackDOHC is offline
Similar Threads
89 cummins 47rh swap, compound turbo, water-meth injection, bigger injectors, etc bmashattack 89-93 Powertrain 7 04-18-2018 02:04 PM
3rd motor rebuild in 10k miles. WTF? firedoger 3rd Gen. Powertrain 14 11-18-2017 03:44 PM
Built 47rh pushing fluid out dipstick after rebuild B_mac_ 94-98 Performance Parts Discussion 8 06-08-2015 11:16 AM
47RH extension housing broke and need to swap mopar01 94-98 Powertrain 0 08-13-2011 12:03 AM
Who has the most miles befor Tranny Rebuild??? slow-poke 3rd Gen. Powertrain 17 05-18-2011 02:40 PM
