Low oil pressure at idle and operating temp - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 02-07-2019, 02:36 PM Thread Starter
Hey I have a 98 12 valve 5speed and I have low oils pressure at idle like 3 psi. But if I hold the throttle at 850 rpm when coming up to stop signs it’s fine it drops to 32/34 psi. I took the 4ks out of it because I couldn’t keep a head gasket together but never turned the idle back up. Could it be to low of an idle? The heads been decked and the engine has been overhauled about 50,000 miles ago. Another thought was the timing was off when I did the valve lash. Any help is greatly appreciated.
Sinserly Earl
Earl12valve is offline
post #2 of 3 (permalink) Old 02-07-2019, 02:39 PM
The Uppity 12v Guy
dauntless89's Avatar
Are you using a mechanical gauge? What is your idle speed?
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is online now
post #3 of 3 (permalink) Old 02-10-2019, 12:54 AM
Cumstromax's Avatar
If it is your gauge on the cluster then the oil pressure sensor is on its way out. If its mechanical check your fittings for oil clogging.
Cumstromax is offline
Similar Threads
48re soft shift and lockup Tekkaomega 3rd Gen. Powertrain 88 12-16-2017 02:08 AM
Rev hang? Cunnart 3rd Gen. Powertrain 19 08-09-2017 01:45 PM
2005 Dodge Ram 2500 48RE Madmike13 3rd Gen. Powertrain 4 07-26-2017 12:46 PM
New 47re doesn't move. Valve body? PittsburghMXrider 98.5-02 Powertrain 42 07-24-2015 02:30 PM
Trany trouble lfr101 3rd Gen. Powertrain 11 11-25-2011 12:20 AM
