1996 face lift - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 20 (permalink) Old 01-20-2019, 04:38 PM
Originally Posted by pa coal roller View Post
The raptor liner is the best thing on the market for do it ur self liner it's easy to spary very little mess to clean up. Just sand with 80grit if u have bare metal just spary primer on it than sand. U can spary at different air pressures I sparked the bottom at 60psi gives very little texture now my bed I will spary at 30psi to give it a lot of text. Best stuff on the market I think plus you can spary it what ever color u want. Also make sure its warm out when u spary it or u have a heated shop.
This is my uncles 2017 chevy that I sparied with raptor liner.
That's a clean finish. Is the gun reusable, if so I assume it cleans up well with mineral spirits or a thinner? I've also wondered about sin fading over time. I really want to do the rocker panels on my 02. Gravel roads are a killer. I live 3 miles down one...
William Dillon Self is offline
post #14 of 20 (permalink) Old 01-21-2019, 10:07 AM
Good Job !
Looks Good !
05 2500 Quad 4x4 Auto , Smarty Jr & . 3:73 Ratio
190,000 miles
95 2500 Quad 4x4 5 Spd. 3:55 Ratio. 95K original miles
rebelrick is online now
post #15 of 20 (permalink) Old 01-24-2019, 08:53 AM
Where do you order your body panels from? I am needing to do something similar.
97 Dodge 2500 4x4, KDP Fix, BHAF, 3 in 1 glowshift gauge (boost, egt, fuel pressure), 4" turbo back MBRP exhaust, 3k governor spring, boost elbow, afc live, tork teck 20 OFV, 650 hp rated transmission from PDD
sdnative13 is offline
post #16 of 20 (permalink) Old 02-14-2019, 11:02 PM
JR
razor1976's Avatar
pa coal roller, you deserve a lot of credit for resurrecting that rig. gives the rest of us a lot of inspiration. way to go.
Get busy living or get busy dying.
razor1976 is offline
post #17 of 20 (permalink) Old 02-15-2019, 02:37 AM
Well done, Sir!
autovon is offline
post #18 of 20 (permalink) Old 02-15-2019, 07:58 AM Thread Starter
pa coal roller's Avatar
Thanks guys. If anyone is thinking about raptor liner. It's good stuff it drys hard does not stay rubbery like other liners. Also feels like liner x . I use 4 bottles on the bottom side of the truck. I still got the bed to do which I will use 8 bottles. As for the paint gun I use to paint truck with. I use one of the new 3m guns theres no cleaning the gun no mess. The tips just pull off throw them away and the cup is part of the tip.
2012 cc dually 6speed, mini max, cooler delete, h&s intake horn, boost tube,5ich pipe,gdp big line kit Amsoil dealer since 2006
1996 12v 430000 miles. Built trans. 62mm hx 35 90hp injectors
pa coal roller is online now
post #19 of 20 (permalink) Old 02-15-2019, 09:26 AM
2Nubs's Avatar
Man, excellent work. That's a good looking truck.
'95 Cummins
2Nubs is offline
post #20 of 20 (permalink) Old 02-15-2019, 10:31 AM
alanack6795's Avatar
I need to paint and throw a transmission in my cab swapped truck. My frame was good but the cab was rotted beyond repair
alanack6795 is offline
