what are yalls mpg - Page 5 - Dodge Cummins Diesel Forum
 14Likes
post #49 of 58 (permalink) Old 02-09-2019, 12:25 PM
bamtech1's Avatar
It just has a slider bar where you guesstimate it at each fillup.
1996 2wd 5speed, AFC Live and boost elbow ,otherwise stock.
1996 2500 4x4 5 speed. Bone stock
bamtech1 is offline
post #50 of 58 (permalink) Old 02-14-2019, 11:58 PM
razor1976's Avatar
15-16 in town. 18-20 highway. It varies. gonna try a fuel additive and an oil additive and see if there is any difference. somehow i doubt it. 97 3500 auto 2wd. empty.
1998 Dodge Ram 2500 12 valve
razor1976 is offline
post #51 of 58 (permalink) Old 02-17-2019, 09:41 PM
'98 12v, 5sp, mixed driving, 17 winter, 19 or better summer. plowing or pulling a goose neck 11
koonta is offline
post #52 of 58 (permalink) Old 02-18-2019, 12:25 PM
2Nubs's Avatar
I thought I had somehow gained some mpg this weekend. I had almost 600 miles on a tank but somehow had a quarter tank left. Well, I sensed something was amiss and went to the gas station on my way home. It held 35.2 gallons... So glad I didn't run it dry.
'95 Cummins
2Nubs is offline
post #53 of 58 (permalink) Old 02-18-2019, 02:02 PM
razor1976's Avatar
maybe install a bed tank?
post #54 of 58 (permalink) Old 02-19-2019, 09:51 AM
2Nubs's Avatar
I don't necessarily need more range. I'm okay with 600 miles to a tank. In fact I love it. My last daily driver was a jeep on 40's with a 10 gallon fuel cell. That was horrible.
I guess my fuel gauge had some how got stuck at 1/4 tank. After I filled up it randomly shot up to full like the float had been stuck so it is working as of now. I had tightened the big nut? on top of the tank the day before as it was leaking after topping off. Maybe I somehow twisted the sending unit. I'll find out when it gets back to a quarter tank.
'95 Cummins
2Nubs is offline
post #55 of 58 (permalink) Old 02-19-2019, 10:41 AM
There sending units are noted for sticking and wearing the contacts in spots.
Sent from my LG-H932 using Tapatalk
2Nubs likes this.
hemirunner426 is offline
post #56 of 58 (permalink) Old 02-19-2019, 11:04 AM
2Nubs's Avatar
Good to know. I'll look into it. Seems that there may be enough room under there to remove and replace without dropping the tank or lifting the bed.
'95 Cummins
2Nubs is offline
post #57 of 58 (permalink) Old 02-19-2019, 11:05 AM
Stox225's Avatar
There’s not lol. Lifting the bed is the easiest method though. Don’t need more than about 6”.
1997 Cummins 2500; NV4500HD; SB DD; 315/75R16; Spohn Performance 3rd Gen Track Bar; Core 4x4 Adjustable Control Arms; 98-99HD Steering; Spohn Performance Steering Gear Box Stabilizer; 63/65/14; AFC Live; PDD 7mm DV's; 4 GSK; Mac Rack Plug; Custom Fuel System; PDD 5x.012; Colt Cam "Big Stick"; 60# Springs; PDD Stage 1 Push Rods; O-Ring Head; Head Studs; KDP Fix; Fluidampr; Boost/EGT/FP Gauges; BHAF; Interior Modifications
Stox225 is offline
post #58 of 58 (permalink) Old 02-19-2019, 11:45 AM
2Nubs's Avatar
Well dang lol. Thanks for the heads up.
Stox225 likes this.
'95 Cummins
2Nubs is offline
