Idle issues - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 05-28-2018, 03:55 AM Thread Starter
Ryan1994's Avatar
Idle issues
I’m new to this but today I was driving went to stop and the truck held 1500 rpm in neutral it has never done this I turned the truck off started it about 20 minutes later it idled fine once I pushed the gas pedal it went back up to 1500rpm got half way home and it went back to normal and would idle down what could be my problem any help would be appreciated
1994 12 valve.5speed Motor has about 3 thousand miles on it
Ryan1994 is offline
post #2 of 5 (permalink) Old 05-28-2018, 08:12 PM
Sounds like something could be loose in your linkage. Check and make sure nothing is binding.
1998 2wd 12 valve
2006 Mega cab 4x4
jknowles4 is offline
post #3 of 5 (permalink) Old 05-29-2018, 12:15 AM Thread Starter
Ryan1994's Avatar
Thank u I will try to look closer tomorrow
Ryan1994 is offline
post #4 of 5 (permalink) Old 07-13-2018, 12:13 AM Thread Starter
Ryan1994's Avatar
Still having problems with it idling down right away sometimes I have to tap the gas pedal to make it idle down any thought of where my problem is it mainly does it when i stay at a constant rpm for a couple minutes any help would be great thank you
Ryan1994 is offline
post #5 of 5 (permalink) Old 07-13-2018, 10:51 AM
GAmes's Avatar
iTrader Score: 7 reviews
What have you done so far?
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
