No Start After replacing rubber lines - Page 3 - Dodge Cummins Diesel Forum
post #25 of 27 (permalink) Old 01-07-2018, 10:58 AM
GAmes's Avatar
iTrader Score: 7 reviews
Originally Posted by GAmes View Post
That isn't exactly accurate. The screen is a basket that holds fuel so that if the tank is low the line won''t suck air while driving up and down hills.
I misspoke here. Obviously the screen isn't a basket because it won't hold fuel and if it did there wouldn't be enough in it to drive 10 feet. I put together this thread, and perhaps D89 will see fit to add it to the tech section.
https://www.cumminsforum.com/forum/94...-canister.html
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is online now
post #26 of 27 (permalink) Old 01-08-2018, 07:14 PM
That isn't exactly accurate. The screen is a basket that holds fuel so that if the tank is low the line won''t suck air while driving up and down hills. Fuel (and dirt) can and will bypass it in the canister. If it was redundant we wouldn't have all the threads where cleaning the pre-filter solved a fuel pressure problem.
I never even considered this when I bypassed the heater setup. Should I go ahead and put a pre-filter on the frame rail down where I started the rubber lines? If so, any recommendations? I have a new Fram inline fuel filter in my garage, what about using that?
1996 Dodge Ram 2500 ECLB Automatic 4x4. Too many mods for the 3 lines I'm allowed.
2017 Ram 3500 Tradesman Quad Cab Dually Automatic 4x4
TorqueWinsRaces is offline
post #27 of 27 (permalink) Old 01-08-2018, 08:11 PM
GAmes's Avatar
I wish I could help you with good technical advice, but I can't. There are a few threads about installing a filter prior to the lift pump. When I deleted the heater that is all I did. Unscrewed the pre-filter screen holder, unscrewed the heater element, then installed the pre-filter holder into the vacant hole. 10 minute job, just a small diesel bath.
GAmes is online now
