Amsoil bypass systems vs enclosed bypass - Page 2 - Dodge Cummins Diesel Forum
post #13 of 17 (permalink) Old 12-01-2017, 07:56 PM
krs
Centrifuges are the most efficient. They remove down to 1 micron. Hence why they put them on the big compressor motors in the oil / gas industry.
https://www.dieselcraft.com/
If I were to upgrade the filtration on my trucks it would be one of these.
17 Ram 5500 CC84" Laramie AS69RC 4.44, BrutusARW Deck, HIAB077, BD PAS, RaceMe/Twister/Stack, Toyo M655, Espar
14 Ram 3500 CCLBDW Laramie AS69RC 3.73, Espar, TrailReady Fr FabFours Rr Bumper, Rigid, BD PAS, RaceMe Ultra Twister Resonator, Fox 2.0, 1-pc DS, Toyo OCCT
06 Ram 3500 CCLBDW Laramie 48RE 3.73 Espar, ARB, Kenwood, Miller, BD PAS, EMF, Toyo M55
14 Ram 3500 CCLBSRW Laramie 68rfe 3.42, RaceMe/Edge CTS, CCV/EGR/SCR/DPF delete, Twister, GoodYear
17 RoadKing, 17 BMW F800R, Cargomate 24'
krs is offline
post #14 of 17 (permalink) Old 12-01-2017, 08:05 PM
GAmes's Avatar
iTrader Score: 7 reviews
Let me guess. You haven't upgraded because the cost is significantly more than the benefit.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #15 of 17 (permalink) Old 12-01-2017, 08:22 PM
krs
No, I don't see the necessity for it. I just use amsoil and delete my trucks. i change oil every 25000kms. Always plug them in. Winter fronts. Do good break in periods on the motors. My 07.5 I sold in January had 300000kms on it and it was mint. Didn't burn any oil and I started to change the oil once a year which ended up being 30-40 000kms. I had an Espar heater on it which helped a lot.
krs is offline
post #16 of 17 (permalink) Old 12-01-2017, 08:54 PM
GAmes's Avatar
Brand of oil means nothing when it comes to filtration. If it did, why would there be a filter at all? Just pour in some Amsoil and drive? I don't think so. 25,000 KMs is only 15,500 miles. Class 8 trucks with bypass systems go 100,000 + miles between oil changes. I wouldn't expect an engine with 300,000 Kms to burn any oil, 186,000 miles is nothing with a modern engine. My original engine didn't start using oil until I was over 500,000 miles, and that was before I discovered bypass filtration. Oil of choice? Whichever was on sale including lots of Wal-Mart Supertech. Filters of choice? Fleetguard Stratapore.
GAmes is offline
post #17 of 17 (permalink) Old 01-12-2018, 02:26 AM
Consider this a thread revival. After doing a search for oil bypass filter, this thread was the first to come up. I have already found useful suggestions in previous posts, namely the use of Fleetguard LF9028 oil filter.
More that one person has mentioned the building or fabrication of a bypass filter system. Where would I start my search to build my own 2 micron oil filter? I understand the concept of pulling oil from the current filter housing and putting it back in the engine oil fill tube. Any suggestions for suppliers of a homemade oil bypass filtration parts would be greatly appreciated.
1997 Ram 3500 one ton dually. NV4500.
rat puke is offline
