Starts then dies - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 10-01-2017, 10:25 AM Thread Starter
bleedcummins's Avatar
Starts then dies
My dad called me up the other night said his 95 will fire up and if you don't touch throttle it'll idle for 2 seconds then die. Fires right back up. Hold at 1/2 throttle it will idle for 5 seconds gen die. Hold throttle to floor it will keep running (till it snaps out of it?) sounds like it's losing prime or sucking air, but after it dies it will fire right back up and doesn't require bleeding system. I'm not a p7100 dude so needing some help. I ahvent been around it so I don't have any personal experience with what it's doing, just what I'm told. He said it seems to run fine for the 2 or 5 seconds before it dies
'02 Auto, s357/s475, 6x.013, Edge cs2 competition, DTT [email protected]
bleedcummins is offline
post #2 of 5 (permalink) Old 10-01-2017, 02:58 PM
PTSCummins's Avatar
Is the Fuel Shutdown Solenoid staying up when running? It's a solenoid with 3 wires on the side of the P7100
Sent from my ASUS_Z012DC using Tapatalk
1999 Ram 2500 QCLB - SO 24V in front of NV4500 and SB DD 3250. Fresh rebuild with ARP studs, CR head, 150HP F1s, Raptor 100, Quadzilla Adrenaline and HX35/S475 (1.10)
PTSCummins is offline
post #3 of 5 (permalink) Old 10-01-2017, 09:04 PM Thread Starter
I don't know. If I remember correctly, if you unplug the wiring the shutoff should stay in the "run" position?
post #4 of 5 (permalink) Old 10-01-2017, 09:05 PM
PTSCummins's Avatar
No. It requires constant 12v power to run. Sounds like the pull circuit is working, but the hold part or relay isn't. Running at WOT may push enough fuel for the pump to ignore the FSS position.
post #5 of 5 (permalink) Old 10-01-2017, 09:27 PM
alanack6795's Avatar
Sounds like a fuel pressure issue to me. Probably the OFV.
alanack6795 is offline
