Center / Carrier Bearing size - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-30-2017, 12:33 PM Thread Starter
b4black's Avatar
Center Support / Carrier Bearing size
I tried searching and couldn't find answer.
What size is the center driveshaft support bearing? I see 35 (1.378") and 40 mm (1.5748") listed. I have a '96 2500 HD
Is there a way to tell without removing it? I want to have it on hand to minimize downtime. Thanks!
1996 Dodge 2500 TurboDiesel 4x4 auto
- KDP, Steering Box Stabilizer, HD T steering links, Boost-pyro-trans temp-fuel pressure gauges, 4" exhaust, Goerends 47RE, 3000 GSK, S300G turbo (174430 57/65/14), AFC Live
b4black is offline
post #2 of 5 (permalink) Old 09-30-2017, 03:38 PM
u2slow's Avatar
On a '93, its the bigger bearing. I suspect all cummins trucks use the big one.
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |4" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
90 D250 6BT |5spd |D60/3.54/Lockright
u2slow is offline
post #3 of 5 (permalink) Old 09-30-2017, 06:58 PM
TheKid760's Avatar
I replaced my 1995 ram 3500 4x4 club cab bearing a couple years back.
Mine was Dana part # 2118481X
https://www.rockauto.com/en/parts/da...+support,12743
1.574" ID
I would double check yours though.
Sent from my LG-H810 using Tapatalk
95 3500 4x4 5spd 4.10 - SuperB/GTA4202 Build, Colt stage 4 Cam, Ported Head, 7mm DV, 7x.012, blah, blah...
TheKid760 is offline
post #4 of 5 (permalink) Old 10-01-2017, 08:11 PM Thread Starter
b4black's Avatar
Thanks. I'm thinking it's the larger 40 mm bearing as well.
Sometimes the 40 mm in listed as "with DANA axle",
And it looks like the 35 mm has mounting tabs on the outside with screws going upward. The 40 mm has screws going into the body from above. My truck has that second style of mounting.
Timken is part # HB88108D. Autozone has the same part number, but under their own brand for less. I might go take a look and see if they are the same.
b4black is offline
post #5 of 5 (permalink) Old 10-04-2017, 12:28 PM Thread Starter
b4black's Avatar
My truck used the 40 mm.
And the Autozone part was made by Timken in a Timken box. Nice when the local store is cheapest.
Cut the old one off, used a 12" piece of 1˝" pipe to pound the new one on. Install the bearing and bell shaped oil slinger together.
b4black is offline
