NV4500 rebuild...slow/sticky first gear - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 09-27-2017, 09:16 PM Thread Starter
austinbrose's Avatar
So I'm in the middle of half rebuilding my transmission. It doesn't have many miles and the main bearings went out...and also spun on main shaft(not under warranty anymore, not my fault and how on earth did that bearing even spin?). Anyways I'm reusing syncros and stuff. Moving everything over and going well, but first gear doesn't seem to spin as well as reverse or second right now. Are the syncros just a little sticky right now or did I somehow screw something up? It doesn't really seem possible to actually assemble it wrong, or did I find a way? Thanks
1994 2500 Regular cab 5 spd 4x4 290,000 4k gsk, afc live, gauges ect. "stock-ish"
austinbrose is offline
post #2 of 2 (permalink) Old 09-28-2017, 11:57 AM
1070's Avatar
Did you set the end play correct on the main shaft. There are shimes behind 5th gear to set it. ? 02 to .04 thousnds end play if I remember correct.
94 5sp 4x4 4x13x155 2x4 to 4x4 converson.ford dana 60 lockout hubconv. 91.5 gas to 6bt conv. 2x4 to 4x4 conv.5x12x155 16deg timming fass 95 nv4500 conv p pump conv. 05 fass95 d60 lockout hub conv ats conv BD trans controller
1070 is offline
