fuel leak help - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-27-2017, 10:29 AM Thread Starter
fuel leak help
1998 12 valve 2500 2wd. I still cant get my sig to accept my info. Alright so my fuel leak from the filter housing finally killed the starter so now it needs to get taken care of. I know (at least I think I do) where it's coming from but I don't know how to assess it. The top of the fuel filter housing is wet from diesel. The hard line that goes to the IP is dry, the hard line that comes from the injectors around cylinder 6 is wet at the banjo bolt. And the retaining nut for the filter lower housing is wet. I believe the line from the injectors is a fuel return line if I'm not mistaken but correct me if I'm wrong. How would one fix that? New washers for the line? Where would I get them? Also if it is leaking from the retaining nut for the lower housing, how would one fix that as well? I'll try and post pictures later as I'm currently on the way to a MLB game lol. Thank you in advanced guys
1998 qclb 12v 2wd auto. All stock plus exhaust. Finally cut the tamper bolt
txcummins98 is offline
post #2 of 5 (permalink) Old 09-27-2017, 10:46 AM
GAmes's Avatar
iTrader Score: 7 reviews
Our filter heads are famous for cracking and leaking. The banjo bolt gaskets don't normally just all of a sudden start leaking. The center bolt is known to break but that normally allows the whole filter bowl to drop. It is a PITA to remove and replace, but it can be done. Genos used to sell a '96 type for a screw on filter but they no longer show it. I'd be searching out someone who has switched to a FASS or is parting out his engine.
GAmes is online now
post #3 of 5 (permalink) Old 09-27-2017, 10:51 AM
GAmes's Avatar
Should have answered the questions. Quickserve has the part numbers for the banjo bolt gaskets. The small o-ring that comes with the filter and has to be installed on the filter housing neck is what keeps the retaining nut from leaking.
GAmes is online now
post #4 of 5 (permalink) Old 09-27-2017, 11:04 AM Thread Starter
I'll definitely have to give that a look. I believe that little o ring is good cause I changed all that when the turbo went. I used the magic of photo editing to show where it's wet or seems to be coming from. Red and green are wet and are the possible sources. Blue us dry as can be. If it's the seal on the nut then that could explain why the whole top of the housing is wet and drips onto the starter. But if it's only the small drain line and banjo bolt (red) it should be contained to on of the small pie piece sections of the housing. If the housing is bad I'll check the 98 12 valve at wrench apart and see if it's good or find a kit for the 96 style housing. I would just upgrade to a new system like a Fass but that's a little more than my wallet can handle right now
post #5 of 5 (permalink) Old 09-27-2017, 11:05 AM Thread Starter
There we go I got it uploaded
