Pushrods - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-25-2017, 08:17 PM Thread Starter
Pushrods
I'm kinda new to the 12 valve but I did a head gasket replacement cause mine was leaking everywhere and I read that I needed to make sure my pushrods were put back into their seats and I was wondering if someone could shed some light on that
Trider00 is offline
post #2 of 4 (permalink) Old 09-25-2017, 08:23 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
Yeah, you gotta make sure the pushrods are in the socket of the tappet. It's not hard to tell, stick the pushrod down, and then try and pull up slightly, if there's a bit of suction and it doesn't want to come up, then it's seated, if it lifts with no resistance, then it's not. You can play around with one a little to get the hang of it, Once you do, it's super easy.
- '96 2500 ECLB
SB-DD
3.54's, Cooper AT3 265's, Studs @ 150ftlb, Custom GSK,
, 055's, AFC Live,
, AFC Stop-Bolt,
, OBA, OBP,
, Str box brace, SuperSport Headlights,
, couple gauges. 506hp/1080tq
Cowboy303 is offline
post #3 of 4 (permalink) Old 09-25-2017, 08:26 PM Thread Starter
Thanks that helped alot
Trider00 is offline
post #4 of 4 (permalink) Old 09-25-2017, 11:30 PM
Armchair Mechanic
colin91's Avatar
Flashlight and an inspection mirror work as well
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped,
, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
