Bosch pump id - Page 2 - Dodge Cummins Diesel Forum
post #13 of 17 (permalink) Old 09-26-2017, 12:34 AM
Armchair Mechanic
colin91's Avatar
Originally Posted by dauntless89 View Post
They're set up for a right-side mount. Throttle linkage, timing pin, and lift pump would all be on the inboard side if you tried to put it on a Dodge B-series. Probably wouldn't even mount up because of that. Off-hand, the C-series is the only I know of with right-side pump mounting.
Or a rear gear train engine...I believe there are some B series rear gear trains in equipment
1996 2500 ECLB, NV4500, 4X4
Engine: 24 Valve P-Pump Swapped, Crowler Springs, Adj. Timing Gear @ 20*, Haisley L19 studs, DAP 3 Piece Mani, Fluidampr, Southbend DD3250, 5" Exhaust+FTE Resonator
Air: HE351VE w/ Banshee Controller
Fuel: 215HP P7100, Infinite Performance 6x11 VCO, Scheid Conversion Lines, PDD 055s, AirDog II 165, Dual Feed, #0 plate, 4K GSK
Suspension: Thuren 3" Coils, Thuren Sway Bar, DOR Track Bar, DOR Shackle Flip, DOR Extreme Bent Long Arms, Synergy Steering, Fox 2.0 IFPs, Yukon Hub Conversion, Dynatrac BJs, 37x12.5x17 Toyo M/T's on H2s
colin91 is offline
post #14 of 17 (permalink) Old 09-26-2017, 12:35 AM
Armchair Mechanic
colin91's Avatar
Originally Posted by myother4x4isaCJ7 View Post
Thanks, from the sounds of it I'll probably be better off just parting them out or selling as cores...
If you end up parting them out I'll take an AFC housing off one of them...Let me know
colin91 is offline
post #15 of 17 (permalink) Old 09-26-2017, 03:03 AM
The Uppity 12v Guy
dauntless89's Avatar
They exist. If this is what they are, they'll have a reverse rotation cam. I believe that is denoted in one of the serial number digits.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is online now
post #16 of 17 (permalink) Old 09-26-2017, 11:04 PM Thread Starter
myother4x4isaCJ7's Avatar
Tag says it turns clockwise, what way does a normal p pump turn?
myother4x4isaCJ7 is offline
post #17 of 17 (permalink) Old 09-27-2017, 02:22 AM
The Uppity 12v Guy
Clockwise, when viewed from the drive end. So it's probably a right side front-train pump like you'd find on a C-series.
