Inspecting and servicing the throttle linkage - Dodge Cummins Diesel Forum
 2Likes
post #1 of 13 (permalink) Old 11-20-2016, 12:05 PM Thread Starter
GAmes's Avatar
iTrader Score: 7 reviews
Because of another thread I discovered my throttle linkage arm was frozen, so I removed it for repair. Since it was off I also bought a pair of bushing for it, since it had been quite awhile (over 300k miles) since they had been replaced, and the first time were replaced they were well beyond serviceable. Cummins part # for the bushings is 3914353 and the Dodge # is 4425053 Expect to pay about $7.50 apiece for them from either source.
I disconnected the upper portion of the intake tube and pushed it aside for more access. Pop off the throttle rod and see if it needs attention later. Disconnect the throttle cable and the cruise cable and disconnect them where they slide into the bracket. I'm guessing you guys with automatics will have to do something with the TPS. Three bolts hold the bracket to the IP.
Backside of bracket is an easily removed spring clip.
Slide the linkage from the bracket. Don't lose the washer.
I pulled the bushings part way out for the picture.
Although they aren't badly worn I replaced then because I had new ones and because of the wear on the shaft from neglecting them in the past. You can see the thinness of the wall on the one on the left and the groove in the shaft.
Clean the sockets at each end of the throttle rod and take a good look. Even though I routinely lube mine one the insert in one of mine was worn through.
Reassemble and reinstall. The whole job shouldn't take much more than an hour.
Name:	back of linkage.JPG
ID:	865755   Click image for larger version
Name:	linkage dissassembled back.JPG
ID:	865757   Click image for larger version
Name:	worn shaft.jpg
ID:	865759   Click image for larger version
Name:	worn socket.jpg
ID:	865761   Click image for larger version
Name:	bushings showing.jpg
DanG144 and mrorganic77 like this.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
The Following 5 Users Say Thank You to GAmes For This Useful Post:
brownbear (11-25-2016), DanG144 (11-24-2016), jimduchek (01-23-2020), jojosdad (11-26-2016), MotorCityMadman (11-25-2016)
post #2 of 13 (permalink) Old 11-20-2016, 01:24 PM
Destroked 450's Avatar
So that's why one of mine was loose and flopping around, the bushings where completely gone, I'll have to check the shaft to see if the unit is rebuildable, does the spring come in a kit, mine's broke.
I don't need it as I've changed to a MD truck linkage but if it can be rebuilt cheap I'll put it in my sellable parts inventory rather than the scrap pile.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #3 of 13 (permalink) Old 11-20-2016, 03:30 PM Thread Starter
GAmes's Avatar
According to quickserve the lever and spring come as a unit. Cummins # 3931569
GAmes is offline
post #4 of 13 (permalink) Old 11-24-2016, 05:04 PM Thread Starter
GAmes's Avatar
I was paging through my new Genos catalog. They have the bushings for $5.30 each.
GAmes is offline
post #5 of 13 (permalink) Old 11-24-2016, 10:33 PM
GAmes,
Can you describe how or where the throttle linkage was frozen in a bit more detail?
Perhaps more on HOW to determine it was frozen, as well?
97 2500HD Club Cab, 4x4, automatic. Isspro Gauges (great support!), Tork Tek OFV (great support!), Diamond Eye SS 4" exhaust (good product).
Chapin, SC or Avery, TX.
DanG144 is offline
post #6 of 13 (permalink) Old 11-24-2016, 10:56 PM Thread Starter
GAmes's Avatar
The piece with the spring is supposed to bend in the middle. Mine had some corrosion oozing out of the crevice where the two pieces meet and would not bend. I soaked it with penetrant, then put one end in a vice and broke them free.
GAmes is offline
post #7 of 13 (permalink) Old 11-24-2016, 11:02 PM
Thanks for the clarification.
DanG144 is offline
post #8 of 13 (permalink) Old 11-25-2016, 09:38 PM
Thanks for the nice write-up and pics, GAmes. It just so happens I've been having some weird, intermittent throttle issues lately. I went to hit the accelerator a few days ago, and it felt like it was completely frozen and would not budge. I had to stab it hard with my foot to get it to move again. I popped the hood and looked at the linkage and it was tight, but I think I still need to take it all apart and inspect it. Something is NOT right.
'97 3500 4x4 CC DRW, 4.10, Banks PP, BD tc, vb, eb, 60# springs, Torqloc, gauges, Weatherguard, B&W...
'92 CC W350 DRW sold '92 CC D350 DRW sold '12 Laramie CC 3500 4x4 SRW sold
brownbear is offline
post #9 of 13 (permalink) Old 11-26-2016, 09:50 AM Thread Starter
GAmes's Avatar
I did some online searching for the CANZ9700 parts kit and see that the few who have them are scalping, big time. So, it might be a less costly option to just buy a rod assy. I don't know the Dodge part #, but Cummins is 3931468 for the rod, or 3931513 and 3931566 for just the rod ends (one is left hand thread). Before doing that I would visit a local dealer and ask at the parts counter for the kit.
GAmes is offline
post #10 of 13 (permalink) Old 11-26-2016, 09:55 AM
Could your symptoms be due to an FSS not fully lifting?
DanG144 is offline
post #11 of 13 (permalink) Old 11-26-2016, 11:04 AM
Are you getting the proper movement and throttle breakover now?
1996 Dodge Ram 2500 ECLB Automatic 4x4. Too many mods for the 3 lines I'm allowed.
2017 Ram 3500 Tradesman Quad Cab Dually Automatic 4x4
TorqueWinsRaces is offline
post #12 of 13 (permalink) Old 01-23-2020, 04:19 PM
The Uppity 12v Guy
dauntless89's Avatar
Reopened for OP edit.
'95 2500 ECLB 4x4, 334k and paused due to epic transformation in progress.
dauntless89 is offline
