Truck won't start - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 05-05-2016, 09:54 PM Thread Starter
Truck won't start
Hello I have a 96 12v 5 speed the other day it wouldn't crank even with a jump so I pull started it to and from work got a starter in my way home put a new starter on it and it still won't crank I have 12 volts at starter I ran cables right to the starter and it won't crank even when you cross the posts I tried another new starter and the same issue and now it won't even pull start please help I'm out of ideas
Jakehaught999 is offline
post #2 of 7 (permalink) Old 05-05-2016, 11:58 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
When you measured 12V at the starter, did you have the starter engaged? Where did you have the probes?
Gandalf the Donkey Hauler - '96 2500 ECLB G56 SB-DD NP241CLD 3.54's, Firerings @ 160ftlb, PDD 4K GSK, PDD 5x18's @ 260, 025's, AFC Live, 28 Cogwheel, AFC Stop-Bolt, HO LP, TPP Manifold Blanket, P&P, Billet 56/64 HX35/GT45 W/Spring gate, EB, OBA, OBP, CC High Idle, BRA, Hotrod PS Pump, Str box brace, SuperSport Headlights, DIY GN Hitch, couple gauges. 733hp/1350tq at NWDC.
Shaughty - '95 2500 RCSB 2WD, PDD 850hp Trans, a lot less than 850hp.
Cowboy303 is offline
post #3 of 7 (permalink) Old 05-06-2016, 12:00 AM Thread Starter
I had positive on big starter post and negative on the starter case I thought maybe a bad ground
post #4 of 7 (permalink) Old 05-06-2016, 12:17 AM Thread Starter
I'm just confused the battery's are 6 months old it has a new starter I hook jumpers to another truck and try to bridge the starter with a screw driver and it won't even spin and now after pull starting it a few times to get to work it won't even start with a pull
post #5 of 7 (permalink) Old 05-06-2016, 02:08 AM
The 10th Man
Cowboy303's Avatar
Turn the key to the "start" position while measuring the voltage at the starter like you did. What you describe sounds like a bad connection somewhere. In order to pull start the engine, the FSS must be in the up position.
post #6 of 7 (permalink) Old 05-06-2016, 07:20 AM
I agree, based on the limited input, you have a bad connection at the battery or one at least one end of the major cable to the starter or to the engine/chassis ground.
As cowboy303 says, tie-wrap your FSS into the up position for pull starting.
The easy way to determine where the high resistance is in the cable:
hook up a voltmeter, positive on the battery, negative on the starter large post, monitor it while cranking. It should read less than half a volt.
Then hook up negative lead to battery, touch positive lead to clean metal on the starter housing, and monitor while attempting to crank. Again it should read less than half a volt.
The high resistance connection, especially if it is a cable lug, will often get very hot when cranking.
More details are in the "starting" section of the free factory service manual that you can download at the top of this forum.
97 2500HD Club Cab, 4x4, automatic. Isspro Gauges (great support!), Tork Tek OFV (great support!), Diamond Eye SS 4" exhaust (good product).
Chapin, SC or Avery, TX.
DanG144 is offline
post #7 of 7 (permalink) Old 05-06-2016, 07:43 AM Thread Starter
Thank you I'll try that
