Oil coming out of dipstick - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 05-03-2016, 07:28 PM Thread Starter
Alright, I am sure that this has been talked about before but I am new here so go easy on me. Here's my issue.....i have oil coming out of the dipstick tube,1ST-the tube coming off of the block is not plugged and/or clogged. 2ND-There is not excessive pressure coming out of the tube off the engine block, i can hold my thumb over it and it doesnt blow my thumb out and when i remove my thumb it sounds like the truck is exhaling, assuming this is proper function. 3RD-When i remove the dipstick, no oil comes out.....
Any help is appreciated
Truck info---95,12valve,4x4,5spd
95-5.9cummins is offline
post #2 of 4 (permalink) Old 05-04-2016, 11:03 PM
Southtowns27's Avatar
It's really common for the rubber gasket "sleeve" at the top of the dipstick by the handle to deteriorate and not seal. I don't think you can change just the seal though, pretty sure you just get a new dipstick. They're for sale all over the internet
96 3500 Ext Cab dually, flatbed 4x4, NV4500, 4.10s, 262K, BHAF, 17*, 100 plate, AFC mods, 024 DVs, 3K GSK, benched by Farrell, Haley 5x.012s, Hamilton 178/208, 165 Beehives, O-ringed, 62/65/14, Coated pistons, ARP studs, South Bend 13" Con-OFE
Southtowns27 is offline
post #3 of 4 (permalink) Old 05-04-2016, 11:41 PM
Ziggylittles's Avatar
+1 for dipstick seal
Ziggylittles is offline
post #4 of 4 (permalink) Old 05-06-2016, 02:23 AM
The Digital Bullet
Common's Avatar
Pop your oil cap off and set it back on loose, does it dance around? Set it back on and leave the hood open. Rev the engine a little bit, does it start to dance?
I think you may have some moderate blowby. But it can be the dipstick.
Use oil at all?
TOTALED 3/23/16
| 1997 Ram SLT 4x4 | 3.55 | Dual Optima Red Tops | AFE Stage 1 | 5" Exhaust | MBRP 6" Tip | ARP Head Studs | TST #10 | 5 X 14 | 4K | 60LB | Air Dog 150 | ATS Aurora 3000 | South Bend 3600 | Auto Meter Pyrometer, Boost and Fuel Pressure Gauges | 20* | PEAK IC Boots |
FOR A QUICKER RESPONSE: [email protected]
Common is offline
