Best location to take boost reading? - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 05-01-2016, 02:01 PM Thread Starter
bbmartin's Avatar
Hi. I need to install my boost sensor for my gauge, and it looks like I can install it in one of two different locations:
  1. In the flat aluminum intake plate that bolts to the cylinder head (where the old intake air temp sensor used to be)
  2. In the port on the back of my Pusher intake.
Any recommendations? Does it make any difference?
This is a '94 12V if that makes a difference.
1978 F-250
- 12-valve Cummins
- NV4500 5-speed
bbmartin is offline
post #2 of 2 (permalink) Old 05-01-2016, 10:48 PM
The 10th Man
Cowboy303's Avatar
Location: 12 days north of hopeless, and a few degrees south of freezing to death.
There is a third option, there is a 1/8 npt port in the plenum next to the Injection pump you can use. That's where many, including myself have there's installed.
I'd choose whichever is easiest, and whichever is most out of the way for doing common tasks like changing filters, pulling injector lines, and such.
The intake horn will have slightly less pulsating, though that really isn't of much concern.
I've had mine in a couple places, Tee'd into the AFC line was definitely the smoothest/steadiest reading, at the inlet of cylinder #6 was among the worst.
regardless of where you put it, you won't see over a psi of difference either way.
Gandalf the Donkey Hauler - '96 2500 ECLB G56 SB-DD NP241CLD 3.54's, Firerings @ 160ftlb, PDD 4K GSK, PDD 5x18's @ 260, 025's, AFC Live, 28 Cogwheel, AFC Stop-Bolt, HO LP, TPP Manifold Blanket, P&P, Billet 56/64 HX35/GT45 W/Spring gate, EB, OBA, OBP, CC High Idle, BRA, Hotrod PS Pump, Str box brace, SuperSport Headlights, DIY GN Hitch, couple gauges. 733hp/1350tq at NWDC.
Shaughty - '95 2500 RCSB 2WD, PDD 850hp Trans, a lot less than 850hp.
Cowboy303 is offline
