Governor Spring Install w/ Pics! - Dodge Cummins Diesel Forum
94-98 Performance Tech articles dealing with gaining power from the 2nd gen 12V engine
post #1 of 14 (permalink) Old 02-27-2010, 12:58 PM Thread Starter
12valveterror's Avatar
iTrader Score: 9 reviews
3000 and 4000 RPM Governor Spring Install with Pictures
By: 12valveterror
What you need:
10mm socket
15mm socket(to turn engine via harmonic balancer bolts)
8mm socket
7/8" socket
screwdriver assortment
pencil magnet
needle nose pliers
First intake and intake tube must be removed from the truck.
Next the fuel shutdown solenoid must be removed. There are 3 bolts. They are 8mm, 2 are at the AFC housing and one is on the backside of the pump.
Next remove the cotter pin holding the shut down solenoid arm to the pump. As well as the 8mm bolt holding this arm to the pump(see pic) notice once that arm is removed there is a small key pin to keep that arm aligned, do not lose it.
With all that removed you can now get to the 7/8" plug which you will be working out of. Remove the plug
This is the bowl o parts thus far:
Now you will see the inside of the pump, oil probably will come out just an fyi.
Next turn the engine(either alternator or harmonic balancer bolts) over to expose first spring assembly.
It will look like this:
Next you need to measure the distance from the top of the stud, to the top of the adjusting nut. It should be between .040"-.050"
Once measured you can then remove the nut, using a screw driver and the upper spring seat using a magnet.
It will look like this now:
Now you will see all 4 springs. I removed them all at once with a good magnet,, but beware of the shims at the bottom. I had 3 in mine.
Once springs and shims are removed you will then be left with the lower spring seat which stock is 2 piece. this is sitting all the way at the bottom of the stud, use a magnet to remove.
Once that is done, you will install new one piece spring seat first, then slide all 4 springs on the stud, put the upper spring seat back on and adjustment nut, tighten back down to original measurement or between .040"-.050".
Turn the engine over to reveal second set and repeat.
Once other set is done, reinstall plug, shut down solenoid bolts and linkage.
Then install intake and tube, fire it up an enjoy.
Engine: Mahle "Marine" Pistons, Balanced Rotating Assembly, ECD Cam, O-Ringed Block, Ported/O-Ringed Head, 3 Angle Valve Job, ATI SuperDamper
Fuel/Air: 475cc P-Pump, 5x.014's, Airdog 150, BW 66/68/14
12valveterror is offline
The Following 30 Users Say Thank You to 12valveterror For This Useful Post:
'89dodge (12-14-2011), 12VEG (07-10-2010), 1995 3500 cummins (09-15-2013), 94_cummins (06-30-2014), 94_cummins_12v (04-28-2013), 96dieselram (02-03-2012), Algae Eater (01-02-2011), Angusbull (01-07-2015), BennyBlaze (11-30-2011), BigRed2500 (02-19-2017), burbn10 (07-23-2010), ckanderson (12-05-2010), Countryboy97 (10-10-2010), Deputydog (09-13-2010), dieselhead29 (04-29-2015), dylon_333 (05-28-2012), dynodave1 (07-17-2012), general440lee (06-28-2011), ifyoucantdodgeitramit (08-27-2012), jlocker92 (04-02-2017), jramon85 (11-10-2012), karale (02-23-2016), Lonno (11-20-2013), Malzan (06-01-2012), michael_d (02-08-2014), oneyeopn (11-11-2013), sofakingbad (12-03-2013), Trost25 (12-12-2010), wgr73 (04-22-2013), zrultima (11-01-2014)
post #2 of 14 (permalink) Old 02-27-2010, 01:08 PM
koolrcr531's Avatar
you actually dont need to take this off, all you have to take out is the cotter pin and take off the fuel shut down solenoid, if you turn it all the way to the right, clockwise, you have just enough room to get the plug off, just a lil less things to take off, and you wont have to worry about aligning it back up
Some stuff to make it go faster than stock (I hope)
koolrcr531 is offline
The Following 2 Users Say Thank You to koolrcr531 For This Useful Post:
Moparman318360 (05-28-2014), WetWilly12 (11-14-2015)
post #3 of 14 (permalink) Old 02-27-2010, 01:10 PM Thread Starter
Yea i know you dont need to take it off but it makes life easier and more visibility, it took less than a minute to pull it off so no harm no foul just a little more room.
post #4 of 14 (permalink) Old 02-27-2010, 01:58 PM
Pwrtrip's Avatar
What exactly are you measuring with the caliper? You cant see that close in the pic.
97 RCLB/Auto, AFC spring, 3000 GSK, #11 Plate, 4" Exhaust, PVCI.
03 crewcab dually/auto. 90hp inj, Smarty, cam, built trans, 3.73's.
Pwrtrip is offline
post #5 of 14 (permalink) Old 02-27-2010, 03:09 PM Thread Starter
in this pic you are measuring the distance between 1 and 2 aka the stud and the adjusting nut
post #6 of 14 (permalink) Old 02-27-2010, 08:31 PM
Thanks for an awesome write up! Could you just clarify: you are measuring the distance from the top of the stud to the upper seat, correct? how it is that you are able to measure this?
ckolloff is offline
post #7 of 14 (permalink) Old 02-27-2010, 08:44 PM
Banned
iTrader Score: 4 reviews
I dont measure stud protrusion. Initial click plus 4 more clicks for this guy
partyshortbusdriver is offline
post #8 of 14 (permalink) Old 02-28-2010, 04:08 AM
Great post. Could have used this about three weeks ago. Lol
02 excab shortbox auto. 5 1/2 inch lift on 37 nitto and 20's. Airdog150, 5'' tb, custom front bumper, sound system and hopefully more to come. 94 reg cab tuned up
Cameron mx698 is offline
post #9 of 14 (permalink) Old 02-28-2010, 02:04 PM Thread Starter
Thanks, no you are measuring the distance from the top of the stud to the nut(adjusting nut) not the upper spring seat. and you use a vernier calipers to measure this or like partyshortbusdriver said you can do it by the clicks, which is first click plus 4 more, i was aware of this way but i wanted to be sure i didnt screw anything up as this was my first time
The Following User Says Thank You to 12valveterror For This Useful Post:
landscapincummins (12-04-2013)
post #10 of 14 (permalink) Old 02-28-2010, 02:05 PM Thread Starter
Also could a mod move this to the tech article section!
post #11 of 14 (permalink) Old 03-01-2010, 11:07 AM Thread Starter
Could a Mod Please Move This to the Tech Section!!
post #12 of 14 (permalink) Old 03-01-2010, 11:04 PM
Deanson's Avatar
man am i the only one that installs gov. springs through the top of the pump?
1997 Dodge Ram 3500 4k GSK, Racked Barrels , 5x.014's,20*,AFC Mods,S400 71/83/.9 ,ARP 12mm studs,5" exhaust,TCS Triple Disk,DTS Tranny,Flex-a-lite fans, LFP9750 oil bypass [email protected] ... I WANNA GO FAST
Deanson is offline
The Following User Says Thank You to Deanson For This Useful Post:
atmechanical (08-10-2011)
