Injector Chart - Page 3 - Dodge Cummins Diesel Forum
94-98 Performance Tech articles dealing with gaining power from the 2nd gen 12V engine
post #25 of 60 (permalink) Old 10-01-2009, 07:00 PM Thread Starter
DTanklage's Avatar
Originally Posted by dontanklage
if you are talking about (*edit) customs there is also 7x13
not such a big jump
yes, like you said, 7x14 is gettin up there
stock 2nd gen inj - vary depending on model but all are 145° injectors
49 state 160 hp - 5x9 .000318
49 state 175 hp 5x9 .000318
180 hp 5x9.5 .000354
160 hp cpl 1863, (actually a 180) 5x9.5 .000354
all calif trucks '96-98 were 180 hp = 5x9.5 .000354
215 hp - 5x10.25 .01025 .000412
300's and 330's same size - 4x12 = .000452
370's - 5x12 = .000565 155° spray pattern
435's - 5x014 = .000769 avail in both 155 and 145° spray pattern
ddp stg III (90 hp) = 50 LPM (liter per minute) 155° 5 hole extrude hone inj <5x12 270 bar
ddp stg IV (140 hp) = 66 lpm - 5 holes smaller than .0135 270 bar
ddp stg 4plus - no longer avail now considered comp waiver must be signed to obtain
ddp comp = 73-90 lpm depending on application same for pop
all four start out as 155° marine nozzles and are extrude honed
the flow numbers (lpm) i posted is what was printed on boxes that i received from ddp
there are posts on other forums that vary slightly with these numbers
measured the holes myself (.0135 gage would not go in a stg 4 ect)
have not used 50 or 75 hp ddp inj - have no idea what size the holes are
custom injectors -
5x.012 = .000565
5x13 = .000663
5x14 = .000769
7x10 = .000549 (24v conv inj are usually 7 hole)
7x12 = .000794
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
7x14 = .001077
5x17 = .001134
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526
5x20 = .001570
ind inj super dragon flows (10 hole) - 5x10.25 + 5x18 .001684
6x20 = .001884
5x22 = .001900
5x24 = .002261
6x22 = .002280
5x25 = .002459 (this is what some refer to as a true competition injector)
*i figured out the csa (cross sectional area) for ea injector. those numbers are in bold
if you want to figure 24v stuff or something that is not on the chart use rē x pi x # of holes
take the hole size divided by 2 times pi (3.14259) times the number of holes
DTanklage is offline
post #26 of 60 (permalink) Old 10-01-2009, 07:09 PM
kjpcummins
Guest
Posts: n/a
i guess i havent heard much about a 7x13 but something to look into but if i step up to the 2.8 class next year ill prolly just say this is what i got for air and fuel i need a injector and see what weston comes up with. The only concern i have is spraying out of the bowl on my truck once i do the ppump swap but i think the 150* sac nozzle and machining the injector to drop it further into the bowl will help alot so i can pull off more timing but not sure if it will have any affect on streetability when running around 22*.
post #27 of 60 (permalink) Old 10-01-2009, 07:14 PM Thread Starter
DTanklage's Avatar
dude - i have been running 21° (towing 22k n all)
never gonna run under 20 again
forget the sac and try to get some blank vco's
*(so you can tighten em up and run even more)
post #28 of 60 (permalink) Old 10-01-2009, 07:27 PM
kjpcummins
Guest
Posts: n/a
how tight can a person go with spray angle ill have more info on the nozzle next week he said something about just having them make a whole new nozzle
post #29 of 60 (permalink) Old 10-01-2009, 07:39 PM Thread Starter
DTanklage's Avatar
thats cuz he cant get the nozzles (sac style)
if you start off with a blank you can go tight as required
weston has a forumla - figure out max timing for any spray pattern on any piston
know what i mean? your bowl is x you want to run x degrees of timing = you need x spray pattern to still be 100% in the bowl
*far as this chart and street injectos goes tho with the stock 2nd gen piston (actually there may be 2 different bowls from 94-97) you can run up to 26° of timing with a 145° spray pattern
18° max with the 155 industrial stuff
The Following User Says Thank You to DTanklage For This Useful Post:
post #30 of 60 (permalink) Old 10-01-2009, 07:46 PM
kjpcummins
Guest
Posts: n/a
with the ho engine 57mm piston bowl its fairly easy to spray out. I see what your saying it will be a few months prolly but we'll see what happens.
post #31 of 60 (permalink) Old 10-02-2009, 11:28 PM
flubyux2's Avatar
Are the MarIne injectors less than desireable on the street with a stock turbo. Or is there no point on searching for some 370s till I get more air?
2006 3500 QcDrw, Laramie, 4wd, 8" on 22.5's and super singles, blow thru with 3x 12's, soundstream, MBrp 5", diy s&b intake, ejwa cts2 + hptuners, torque diesel s1 inj, fass hd150 & 8AN, WW2.
flubyux2 is offline
post #32 of 60 (permalink) Old 10-03-2009, 11:58 AM
xzaq103's Avatar
iTrader Score: 5 reviews
Marines arnt really desirable at all. For what you get you would be money ahead in milage alone to get a good set of injectors.
xzaq103 is offline
post #33 of 60 (permalink) Old 10-03-2009, 12:07 PM
Banned
so for a set of 435's with the 145 degree pattern where would one order a set?
I assume theres a bosch part number?
Saber123316 is offline
post #34 of 60 (permalink) Old 10-03-2009, 12:27 PM
flubyux2's Avatar
Yeah, that's what it's starting to sound like. What's this I've been hearing about one of our own guys who builds injectors, Weston or something?
flubyux2 is offline
post #35 of 60 (permalink) Old 10-03-2009, 02:30 PM Thread Starter
DTanklage's Avatar
weston is not building 12v inj anymore
how much air your charger moves wont be as big a factor as the restriction it creates on the ex side
someone needs to make a chart
with the pump maxed but not benched x injector requires x air
post #36 of 60 (permalink) Old 10-06-2009, 07:42 AM
flubyux2's Avatar
hey don, whats the low down on sac-less/vco nozzles? do people retrofit them onto stock injectors and modify them?
flubyux2 is offline
